Hi MarkF,
Thank you for helping me with a different view of the issue. The reason why I felt the transformer was dead because I measured 200+V in the primary
side (though now, I'm not getting 1/2 that amount) so something busted again) but measured zero in the secondary for all pins. So I had thought that
the transformer died. With your additional help, I'll check the K950x 'things' (what components are represented by K? They're continuous..so I don't get it).
The switching controller could be problematic since I'm supposed to measure 300+V but I only get 100 in the drain. It's a power IC; but according to my search, the STR Y6456 is an obsolete item. If this ic is indeed dead, what would be the best replacement? I've looked at digikey but I can't make heads or tails as to which power IC is the right one. Any help definitely appreciated.
Will continue to work on this project. Thanks for the immense help.
