Thank you!
Addendum: I removed it and checked out of circuit - definitely short between Drain and Source (both directions). Quite how that happened I don't know given that it's rated at 45A and is protected by a 3A fuse! Yeah, I know - corollary 16 of Murphy's law: When you fit a fuse to protect an expensive device in a circuit, the device will always blow first so as to protect the fuse.
PS Mrs. Murphy's Law: Murphy was an optimist.
