Author Topic: If a service manual says inject a 1k sine -20dbm at point X, what is that?  (Read 5015 times)
Offline gooseEL34Topic starter
Ok.
I am somewhat knowledgeable about electronics.  I can read and trace a schematic, troubleshoot to an extent, and have a HP 206 sine generator, a Fluke 77 and a old Tek scope.
I have a digital delay meant for the guitar/audio world.
It was having an odd symptom in that the delay time (which is variable in 1ms increments with a up/down rocker switch), was behaving badly.  Specifically, it would not hold the specific delay time (for example, if I set the delay to 300 ms, it would float up to 310 and fall to 270 etc...
I suspected something with the power supply.  Sure enough, I opened it and found a few caps that had puked their guts.
I was reading the service notes, and after I replace the caps, I plan to set it up per factory specs.
Two of the tests require a 1k, -20dbm sine to be introduced to the input jack.  Another asks for a -10dbm
Most of the time, I have read amplifier schematics and they say "insert a 1k sine at .250v into the input"
What is -20dbm??  Thanks guys.
Offline T3sl4co1l
    • Seven Transistor Labs
The source impedance is going to matter based on what the circuit is doing, so, whether they mean, apply a wave of so-and-so and adjust amplitude until the voltage as measured at the injection point is -20dBm, or they just mean, set it for -20dBm and patch it in... I don't know.  But other than that...
dBm = dB relative to 1mW.  So, again, the source impedance matters as far as what voltage or current it presents... but for 50 ohm generators, 1mW == 0.223V (RMS).  So -20dBm is 1/10th the voltage or 22.3mV (RMS).
Seven Transistor Labs, LLC
Offline kff
This table may be helpful:
http://ifmaxp1.ifm.uni-hamburg.de/DBM.shtml
For 50 ohm impedance and -10dbm, you need 70.7mV RMS or 100mV peak.
Offline Po6ept
Guitar equipment is usually high impedance, but different equipment can use different values.  A few "typical" values are 44K, 60K, and 220K ohms for active devices.  If you know the input impedance, you can use this calculator to determine the voltage.  http://www.coretechgroup.com/dBm_Calculator.php
Offline albert22
If I am not wrong aprox .250V rms corresponds to -10dBm into 600ohm.
AFAIK some audio measurements use 600ohms reference impedance.
It seems that you need .250vrms for -10dBm  and around .08Vrm for -20dBm
« Last Edit: January 22, 2015, 11:27:09 pm by albert22 »
Offline EEVblog
Ok..  Thanks for all the info.
I guess the problem is that I do not know how to determine the input impedance of this unit.
Would that be written on the schematic somewhere (which I do not have)....
Thanks
Offline CZ101
Thanks
-20 dbm in audio generally means - as terminated into a 600 ohm load.
I've found this calculator handy for this http://www.random-science-tools.com/electronics/dBm-Watts-volts.htm
I recently went through a similar quandary trying to calibrate an older mixing console.
Well darn.... that cap did not in fact puke its guts, it was merely the goop used to keep the thing in place.  Plus it was a 47uF non-polarized electrolytic and not in the power supply.
The schematic is here:
http://www.synfo.nl/servicemanuals/Roland/SDE-1000_SDE-3000_SERVICE_NOTES.pdf
The symptom is this:  When the delay time is set (using a rocker switch on the front panel), it will hold at that setting but then start fading (delay time decreasing).
I cannot see any burned or broken or otherwise damaged parts from a visual inspection.
Anybody have any thoughts?   My gut would say that there is a bad DC supply somewhere, but I don't really know where to start (I mainly work on hand wired tube amps that have 1/100th of the components of this thing (and no ICs nor transistors).
Thanks
