Hoping somebody might know what this substance is needed for (please see photos).
Just repaired an old DELL laptop power supply adapter (high ESR 'Ltec' electrolytics...)
To do the work I had to use a scalpel to cut away some of this flexible white material. At first I thought it was simply thermal paste, but there was so much of it used, together with the fact that it was not still wet (or gone dried & crusty over time) like regular silicon heatsink compound.
The main bulk of it was used near the small chopper transformer. Could it be possible that this white material was to "bulk out" some of the internal space to make the power adapter more resilient to bumps and vibration (it is used with a portable device after all...!)? Thanks.
