Author Topic: NF ZM2354 LCR meter ERR77?  (Read 693 times)
Offline mrf245
  • Country: cn
« on: November 18, 2017, 12:59:04 pm »
I got a NF model ZM2354 LCR.
It worked fine until last time I turned on it, It didn't execute normal boot sequence,but displayed "IL ERR 77".
I asked another friend who have some ZM2354, he sadly told me that all of his 2354 also have the same problem----IL ERR 77
Most ERR 77 happened after normal use several times. I check manual it only shows ERR77 is "hardware problem". What hardware problem?
Anyone know how to solve this problem? Thank you very much...
BH7JUO Mark
Offline coromonadalix
Re: NF ZM2354 LCR meter ERR77?
« Reply #1 on: November 18, 2017, 03:10:40 pm »
Seems your lcr had some beating on the top panel case ??? could not find a complete manual ...
Does it have some battery inside ?
Maybe some loose part, connector, socketed chip, or even bad/cold solder ?
« Last Edit: November 18, 2017, 03:12:11 pm by coromonadalix »
