Author Topic: IFR 8000 Spectrum Analyzer  (Read 7439 times)
Offline mauritTopic starter
« on: April 05, 2024, 09:26:36 am »
Hi, I need help with my IFR 8000 Spectrum Analyzer.
Symptom: The keyboard does not respond to any commands,
1) I checked the power supplies and they are OK
2) I disassembled the keyboard, cleaned the keys and they are OK
3) I checked the flat cable and it is OK
4) I changed the C-Mos Battery on the CPU board
only the encoder that acts on the frequency setting works.
Some advice ?
Thanks in advance.
Maurizio
Offline CaptDon
  • Country: is
Re: IFR 8000 Spectrum Analyzer
« Reply #1 on: April 05, 2024, 03:50:44 pm »
If any PLL is unlocked the keyboard will appear dead. Are any of the Red LED PLL fault lights lit?
« Reply #2 on: April 10, 2024, 10:15:04 am »
I don't know where the red LEDs of the PLLs are located,
I haven't found any documentation for this analyzer.
Can you give me some suggestions?
They tell me there is a procedure to follow when changing the backup battery.
I do not know her.
maurizio
Offline korlatos
« Reply #3 on: April 11, 2024, 08:57:35 pm »
I am not sure about the A-8000, but on A-7550, which is almost identical, you need to perform a reset procedure after the battery replacement. The procedure is explained in the attached image.
« Reply #4 on: April 13, 2024, 03:08:26 pm »
There is an LED flashing after boot. Is this normal ?
« Reply #5 on: April 13, 2024, 03:15:21 pm »
Hi Korlatos,
unfortunately, the procedure you indicated for restoring Boot doesn't work.  |O
