Author Topic: IFR1200 CPU Card Corrupted -Dead --Need Help  (Read 4695 times)
Offline try2fixTopic starter
« on: June 17, 2019, 07:26:20 pm »
Hi, hope someone can help, I have read that the eproms inthe IFR1200 can get corrupted over time - So Copied and burnt eproms from a working IFR1200s , put the new eproms in & the cpu card is now bricked- I put the old eproms back in with no change, I took from another IFR1200s a good working CPU card and put in the eproms and it is bricked now --- is there some kind of blanking program that has to be run before changing the eproms ? -- I removed the batt and discharged the caps to try to clear and still no go - the display is blank when the cpu card is not working, all you will get is @@@@@@@@@@@@@@@@@@ flash when you power down the unit  - I put a good CPU card in and the unit works great --but now I have a few dead IFR1200s as I have Bricked there cpu card - any one got any answers please, Thanks
« Last Edit: June 18, 2019, 10:46:31 pm by try2fix »
The following users thanked this post: Chris56000
Offline fzabkar
Re: IFR1200 CPU Card Corrupted -Dead --Need Help
« Reply #1 on: June 18, 2019, 05:46:49 am »
I can't help, but maybe it would help to see your EPROM dumps. Perhaps they contain a unique data block??? Are they special devices, or just off-the-shelf parts? Are there any other non-volatile memories in the unit?
« Reply #2 on: June 18, 2019, 12:43:01 pm »
Thanks, the eproms are 27c512.
I am trying to send the file for you to read but it is a .bin file and I have not figured out how to convert it to a acceptable one for the form--I have a lot of learning to do and helps are welcome
« Reply #3 on: June 18, 2019, 12:50:37 pm »
here is what the files look like from the IFR1200S - There are Two 27c512 chips , bottom and top
« Last Edit: June 18, 2019, 10:49:42 pm by try2fix »
« Reply #4 on: June 18, 2019, 10:44:17 pm »
Here is the file from IFR1200 super s  - it is somehow corrupted or has caused the CPU board to lockup...? it is on a 27C4001 eprom - no successes in it working after I had programed another chip and plopping it in
I have tried on a few IFRs and they work fine untill I put in my locked up cpu cards.  What makes it worse is I borrowed a friends IFR and locked up his cpu card.... there must be some simple way of getting them to wk again... those of you that are good with hex let me know if it looks corrupted.  I have also pulled out the SRAM on the 1200s but cpu still not talking... I am thankful for all and any help ...new to the forum so hope I am doing all correct
Offline TheSteve
  • Living the Dream
« Reply #5 on: June 18, 2019, 11:14:03 pm »
So you've had the same issues with the IFR S and the Super S with different type/size eproms? Perhaps your eprom reader is not getting good dumps.
Assuming others have posted eproms dumps from the 1200 series have you compared them?
VE7FM
« Reply #6 on: June 19, 2019, 12:31:52 am »
I have never seen anyone post a eprom file so I cannot compare, the super s I just read and programed another eprom as I could not fine any one to lend me theirs to read it as a known working file, so it could be corrupted over time but I figure not as when I borrowed a good working 1200s from a friend and read his eproms ,then put the copied ones into his board it reacted the same as the dead/locked cpu board in the super s unit ...........  if you see any post that has files let me know and I can try to compare but I think now it is something that IFR put into a program to crash it as I took another good cpu board and put in the eproms from my friends ifr cpu board and now it is locked/dead, so I put my original eprom back in, no change --I cannot figure as 27C512 eproms are read only what is programed onto them, very frustrating as I have to get my friends IFR back to him in working order before he needs it.
I did a read, program and then verified the chip but kinda out of practice for eprom stuff so could well have messed up the eprom but putting the old back should have brought it back to life----- about 25 yrs back I remember the c band sat boards that you had to put in a blanking chip and then you could drop in the new eprom program and that was with the 27c series eproms... maybe IFR made the same thing ??????????  must be someone around that knows
Offline TheSteve
  • Living the Dream
« Reply #7 on: June 19, 2019, 03:02:35 am »
Had a look at the files you attached. They are all corrupted, there is no valid data in them.
Unless the corrupted data caused hardware damage(unlikely) you need to get some good images and verify your programmer is operating properly.
VE7FM
The following users thanked this post: try2fix
Offline fzabkar
« Reply #8 on: June 19, 2019, 03:59:05 am »
The data repeat in blocks of 0x100 bytes. That is, the data at addresses 0 - FFh is the same as the data at 100h - 1FFh, 200h - 2FFh, and so on until address 0x10000. Then there is a new 0x100-byte block which repeats in the same way until address 0x20000, at which point a third 0x100-byte block appears and repeats until the next 64KB boundary, and so on.
This suggests that address bits 8 - 15 are stuck. Bits 0 - 7 and bits 16+ are OK.
« Reply #9 on: June 19, 2019, 05:11:35 am »
Thanks , I will follow up and read them again to see if I have done something wrong, just learning all about how to read these chips, thanks
Offline fzabkar
« Reply #10 on: June 19, 2019, 08:40:26 am »
I'm betting that your programmer is faulty, possibly a bad octal latch or transceiver. Could we see the programmer's PCB?
« Last Edit: June 19, 2019, 08:43:23 am by fzabkar »
« Reply #11 on: June 20, 2019, 01:18:58 am »
Here is A pic of my programmer, it is a "Universal EPROM pic flash mpu Programmer"
I trided to program a few more chips and I get an error now for each one, I have to figure out what is not setup correct, but still does'nt make sense that the cpu card would not work after I put the originals back in. I'll send out a new file of the other cpu card original chip when I get it read off and you can let me know what you think. thanks
« Reply #12 on: June 20, 2019, 02:20:57 am »
Okay here is the Eprom file that was from a working IFR1200 CPU board untill I replaced the chip from the other cpu board - then I put this original back in and dead cpu board.
So the file is the original, let me know if it looks that way. Thanks
« Last Edit: June 20, 2019, 05:03:52 am by try2fix »
Offline fzabkar
« Reply #13 on: June 20, 2019, 03:03:18 am »
It appears to be a Willem knock-off, PCB version 5.0E.
I examined some Willem circuit diagrams, but I can't come up with a fault scenario which could account for the apparent corruption we are observing.
BTW, the programmer does have a self test facility whereby you can send a user selected address and data combination to an empty ZIF socket. You can then verify the pin voltages with a DMM.
« Last Edit: June 20, 2019, 03:53:57 am by fzabkar »
« Reply #14 on: June 20, 2019, 05:14:27 am »
okay help me out here the chip has a hex number 73E1 printed on it - assuming that is check sum -so I do a checksum but I do not know what I should be in (checksun-16/32/CRC-16 ...ect) - so I am using CRC-16 as it gives the closest of 7F8C --I am using HxD Hex Editor - so I did blank some chips and reprog and finally got it to program without errors using to 27512 seting vs 27c512 -I don't know why but maybe you can educate me about that-but the chip verified as same --but still wondering why the check sums are different:73E1 on chip vs 7F8C using Hex editor.
let me know if you see that I am doing sum thing wrong, Thanks
Offline fzabkar
« Reply #15 on: June 20, 2019, 06:06:32 am »
Your last dump is just like the others, ie there is a block of 0x100 bytes which repeats from start to finish.
As for checksums, there are numerous algorithms in use. In any case it wouldn't be possible to identify the algorithm until we are certain that the hex dump is good.
Offline TheSteve
  • Living the Dream
« Reply #16 on: June 20, 2019, 07:53:34 am »
Try2fix it is a long shot but if you're in the Vancouver area I can help read/erase/program the eproms.
VE7FM
« Reply #17 on: June 24, 2019, 07:41:36 pm »
Thanks, I am in Alberta so that is still about 14hrs drive so don't think I will head over to your place yet, but thanks, maybe you could help me just figure out the eprom stuff - I have been doing tests by reading a eprom that is in a working unit, then I take a erased eprom and program it, compare it by reading it a couple times, ball the same, then I put it in to replace the original and no go, put the original back and it works -- I go and compare again and they r the same ??? what do you think i am doing wrong ?  thanks
« Reply #18 on: June 24, 2019, 08:00:10 pm »
Yes it says Willem Eprom prog
okay help me out to know what to type in to test the pinouts when in the test mode as I am not sure what pin to be testing and when/what...thanks
Offline CJay
« Reply #19 on: June 24, 2019, 08:33:35 pm »
If your EPROM programmer has a problem with stuck address lines it will read the original ROM incorrectly but worse, it will program the fresh ROM with the incorrect data and then it will verify it as correct.
You need a sanity check, find someone with a different EPROM reader/programmer and have them copy the ROM.
« Reply #20 on: June 25, 2019, 01:19:46 am »
Thanks for all the help so far - new findings are that I got most of all the cpu boards going by swapping processor sram and eproms around and found out that it looks like my new eprom reader programmer has somehow fried the 27c512 eproms i read!---how can it do that, i was just reading- any thoughts would be great    --I also have a old programmer but no info on it , any one know what software runs this thing ?  Thanks
« Reply #21 on: June 25, 2019, 01:51:14 am »
Okay can some of you look at these 2 files- The First I got read off a few months back by a friend 3hrs drive away, I have now read that same chip with my reader and it is sure different, Any help would be great to know if the first file looks corrupted and then the second file to the first to try to determine what pins are not working on my reader, Thanks
Offline fzabkar
« Reply #22 on: June 25, 2019, 01:53:14 am »
That looks like a dedicated programmer for 8748 and 8749 microcontrollers (and others).
« Last Edit: June 25, 2019, 01:56:47 am by fzabkar »
Offline fzabkar
« Reply #23 on: June 25, 2019, 04:13:34 am »
I only see 1 file. BTW, why can't you see for yourself that the data repeat in blocks of 0x100 bytes?
« Reply #24 on: June 25, 2019, 04:58:33 am »
Thats different, I loaded 2 files , I guess only one when threw , Here is the first one again- I got a lot of learning ahead
- on reading the files I don't know what I am doing to know that it is a repeat or what, thats why I ask the experts, you all that work with this kinda stuff. Thanks for the info on the old reader, looks like it won't help me for this project
