Author Topic: [SOLVED]Revox B261-LCD segment fault finding.  (Read 683 times)
Online djsbTopic starter
« on: October 14, 2021, 02:52:26 pm »
The lower segments of the second digit (the first zero in 100 from the left) do not appear. I have attached the schematic below. I'm trying to identify which pins to apply voltage to (using my multimeter on the resistance range) in order to turn on these segments. The numbering on the pins is a bit confusing, as each pin appears to relate to more than one segment. Is there a recommended way of testing segments on this LCD without powering up the whole circuit, as I have removed the PCB from the tuner temporarily. I have watched Dave's LCD video's, and he mentions that applying a DC voltage is not the best thing to do. Any advice welcome. Thanks.* Revox_B261_LCD.pdf (635.36 kB - downloaded 49 times.)
« Last Edit: October 17, 2021, 02:04:24 pm by djsb »
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline Alex Wolf
Re: Revox B261-LCD segment fault finding.
« Reply #1 on: October 14, 2021, 03:15:31 pm »
Between Com I or Com II and the segments you want to test.
Offline Runco990
« Reply #2 on: October 14, 2021, 06:15:31 pm »
It is very common with Revox gear that the LCD has bad connections between the glass and the contact strips that hold it.  A little squeeze and wiggle will usually show this.  Did you try this before delving into electrical troubleshooting?  Always try that first.
The following users thanked this post: djsb
« Reply #3 on: October 17, 2021, 02:03:38 pm »
I've moved the contacts on the edge of the glass and now the segments are working again. Thanks.
Hertfordshire, UK
Offline Runco990
Re: [SOLVED]Revox B261-LCD segment fault finding.
« Reply #4 on: October 17, 2021, 11:34:51 pm »
You're welcome!   :-+
