Hello everyone, I hope my inquiry finds you well. I thank you for your time in giving me advice/insight regarding a maintenance/storage failure. Back in December 2020, when I had moved, and especially due to family health matters going on, I became sidetracked and unfortunately did not think of the proper storage conditions for my electronics hobbyist toolbox.
I had (rather unintentionally) left it in my garage, which is not temperature controlled. After the following temperature records I describe below,
I have listed the contents of the toolbox that I am concerned are rendered unreliable now. The following temperatures are those of the outside-the-house temperatures that were recorded, not those of my garage.
In the winter, low temperatures were between -7.1 to -1 degrees C (19 - 30 degrees F), and a highs of -1 to 10 degrees C (30 - 50 degrees F).
In the springtime, low temperatures rose to about 4.4 to 12.8 deg. C (40 - 55 degrees F), with highs approaching 15.5 to 21.1 degree C (60 - 70 degrees F).
Then, in the summer, high temperatures would rise to about 32.2 to 37.8 degrees C (90 - 100 degrees F).
In other words, the garage went from being "very cold" in the winter months to being "very hot" in the summer months.
It is also not exactly a dry place (except for probably in the winter); it is not wet of course (I do not have any mold/mildew issues and do not live near big bodies of water), but the air is humid in spring/summer.Therefore, I am concerned if any of the circuit parts/wires that I had in my box (which was closed tight the whole time) were internally damaged due to these improper storage conditions. Other than visually inspecting the box contents (they seem fine), I have not had the opportunity to try any of them out since I am working two jobs and cannot support any hobby projects at the moment.
But, I figured I'd ask this here in case anyone would theoretically know if my toolbox contents are potentially rendered garbage... or, if anyone has experience with any issues with their circuit/wire parts that may have been brought on by improper storage conditions.
Some of the contents of my toolbox are:
- A whole bunch of resistors, diodes, capacitors, potentiometers, LEDS
- A whole bunch of op amps, 555 Timers, and other ICs
- Micsoa BNC test-lead set (https://www.amazon.com/gp/product/B07FZV589P/ref=ppx_yo_dt_b_asin_title_o08_s01?ie=UTF8&psc=1)
- AUTOUTLET P6100 Universal Oscilloscope Probes (https://www.amazon.com/gp/product/B07P7M72JX/ref=ppx_yo_dt_b_asin_title_o08_s02?ie=UTF8&psc=1)
- Amphenol 112461 BNC Tee Adapter, Jk-Pl-Jk, 50 Ohm Impedance, 4Hz Max Frequency (https://www.amazon.com/gp/product/B005T9PNUY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
- Multimeter Test Leads, Banana Plug (https://www.amazon.com/gp/product/B07MX9FJKD/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1)
- Sumnacon Banana to Banana plugs (https://www.amazon.com/gp/product/B07179VF5J/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1)
- Sumnacon multimeter banana plug to crocodile alligator clip wires (https://www.amazon.com/Sumnacon-Multimeter-Crocodile-Alligator-Stackable/dp/B071SL6PQS/ref=sr_1_3?dchild=1&keywords=banana+clip+wires&qid=1628350187&sr=8-3)
- Sumnacon Multimeter Test Lead Set (https://www.amazon.com/Sumnacon-Inch-Multimeter-Test-Lead/dp/B07VDNHCFM/ref=pd_bxgy_img_1/135-5493630-4357622?pd_rd_w=4P8Sh&pf_rd_p=c64372fa-c41c-422e-990d-9e034f73989b&pf_rd_r=361N9QCTQERF7DXZ78P0&pd_rd_r=7678e4a6-ca9b-4810-bbc4-13691f606d04&pd_rd_wg=mLkut&pd_rd_i=B07VDNHCFM&psc=1)
- about 10 breadboards
- A whole bunch of breadboard jumper wires (https://www.amazon.com/SIM-NAT-Breadboard-Arduino-Raspberry/dp/B06XRV92ZB/ref=sr_1_6?dchild=1&keywords=breadboard+wires&qid=1628352861&s=hi&sr=1-6)
I suspect I might be being paranoid. But that you can tell me.
I just simply know that I should not have stored my toolbox in such conditions. But assuming that they still function seemingly well when in use,
I am simply wondering if I should be ready to find out/be cautious that they are probably not reliable anymore? Thank you for your time in giving your advice and insight. I sincerely appreciate it.
