Author Topic: Induction cooker blown T Fuse and IC md12h  (Read 1154 times)
Offline smileTopic starter
« on: October 30, 2023, 07:11:53 pm »
I have a blown mains fuse that I reset. Forgot to use the lamp while repairing. The induction heater fuse is not blown. there is IC blown md12h. An there is T FUSE like resistor blown.
What to replace the T Fuse with? I ordered IC from aliexpress.
Re: Induction cooker blown T Fuse and IC md12h
« Reply #1 on: October 30, 2023, 07:12:38 pm »
Board front
Offline fzabkar
« Reply #2 on: October 30, 2023, 07:34:59 pm »
Some info on the IC ...
http://www.topctc.com/wproducts_content-102731.html
T-Fuse looks like a fusible resistor. You might need to trace the circuit in that area.
« Last Edit: October 30, 2023, 07:38:44 pm by fzabkar »
The following users thanked this post: smile
« Reply #3 on: October 30, 2023, 07:49:47 pm »
By looking closer t fuse maybe is unuser port to the right, and burned resistor is labeled r33 measures 2 megaohms.
What value it can be? the stripes are not clear. I wonder what schematic I can use as no model number is available.
Found video with similar board, but no schematic link.
Offline fzabkar
« Reply #4 on: October 30, 2023, 08:09:15 pm »
The resistor is situated between two rectifier diodes and a filter capacitor. It carries the full switching current of the MOSFET chopper within the IC. Therefore, it must be a low value resistor, possibly fusible.
Offline fzabkar
« Reply #6 on: October 30, 2023, 08:49:12 pm »
I'm colourblind, but it looks like a 10 ohm, 1 watt resistor to me. I'd go with a fusible/flameproof type.
« Reply #7 on: October 30, 2023, 10:33:04 pm »
In this video 6:12min (similar board ) you can see it is 22Ohm 1%
Here is image also the same value 22Ohm 1%
https://www.flipkart.com/electronic-spices-2200w-220v-circuit-board-coil-electromagnetic-heating-control-panel-pcb-induction-cooker-heavy-heatsink-components-hobby-kit/p/itm869a9656ea518
Resistor seem to be 3W
« Last Edit: October 30, 2023, 10:38:42 pm by smile »
Offline fzabkar
Offline fzabkar
« Reply #9 on: October 30, 2023, 10:49:34 pm »
« Last Edit: October 30, 2023, 10:51:34 pm by fzabkar »
« Reply #10 on: October 30, 2023, 11:01:00 pm »
I found this image also
Offline Swake
« Reply #11 on: November 01, 2023, 07:00:45 pm »
Your R33 is as big as the glass fuse. That is at least 3W.
For the value:
The last picture is a more recent board (V10) so take this with some precaution. Colors I see: Green - Brown - Black - Gold - Black. That is 51 Ohm at 5% tolerance, and the last black ring indicates it is wire wound. A fusible resistor is generally indicated with a white or very light gray ring. 51 Ohm is a standard E24 series value. It is also smaller than the one on your board.
When it fits stop using the hammer
Offline fzabkar
« Reply #12 on: November 01, 2023, 07:21:22 pm »
For the value:
Sorry, I was looking at the wrong PCB. <slaps forehead>
