I have a SmartUPS 1500. I just put new batteries in it. There is a lot of corrosion around the battery compartment. I put the new batteries in, they charged up. The UPS acts like its working ok. But when I kill the power input either by unplugging from the wall or running a self test, it shows as if it drains battery real quick (the Battery Charge LED's drop quickly) and it powers down, because it thinks its out of juice. But actually moving that battery into another UPS of the same model, shows the battery still shows fully charged. So the batterys are actually fine. I even swapped in some batteries from the other UPS (same model) and the same behavior is exhibited. I did a recalibration on the UPS, and tried a "reset" which APC tech support had me do (unplug from wall, power off UPS, unplug battery from UPS, and then plug it all back in). Still same behavior.
My initial question is how can I safely work on this? I took the lid off, and put a meter to the two large caps, they showed about 8.47V each. I was hoping the meter would discharge the caps but it just held 8.47V. So I used a screwdriver and there were a lot of sparks from the one cap, not much from the other, now they show 0V. There are some smaller caps, I ran the screwdriver over those and didn't see anything and got no meter readings on them. Then there are some other large devices like transformer which I assume is likely not to worry about. I want to disconnect some of the boards to have a look.
