Hello,
I've looked for a solution to my little problem for a while and couldn't find an answer. My trouble is a buzzing inductor inside a light dimmer switch. Once I plugged in a single 35W halogen lamp to test it out the dimmer, I've heard the buzz. A pesky coil!
To make sure it was not something else buzzing, I hooked the coil away from the board with a couple of wires. Coil it is.
I am looking to hook up three 35 - 50W halogen bulbs with an option to dim them down when necessary, for which I bought a simple dimmer switch. Is there some kind of a modification I could make to make it less audible? The buzz is relatively low frequency. It is loud enough to be heard from a meter or two away, which is a problem. Not much inside the device: the coil, pot-switch, a triac. You know the drill. Attached a couple of pictures.
Some spec. on the device:
Voltage: 230V, 50Hz.
Power rating: 40 - 400W.
Used for dimming: halogen and incandescent bulbs.
