Had a bit of time to continue to poke around - Here is what I found and posted to the HP user group:
This morning I discovered that I clear failed repair 101 - I didn't notice the jumper missing from the A28 RF Motherboard to the A25 Audio Motherboard:
So I whipped off the covers of my working 8902A and used the jumper from it - Turned on the 8901B and, damn, Error 06 was still displays.
While I had the working 8902A open I thought I'd swap the A20 LO Control Assembly and the A13 Controller Assembly (apart from A15 RF Assembly these seem to be the only place the OVERPOWER signals get acted upon).
Still no dice, Error 06 on the display.
I needed the 8902A for something else so I swapped back this bits, reassembled my 8902A and ordered a small jumper cable to replace the missing one (surprisingly cheap on eBay given that I didn't have either the ribbon cable or the connectors and would have had to order those to make the cable myself anyway).
While I had the 8901B on it's back to remove the jumper cable I finally realized that I could measure the pins directly (doh!) so I set about to measure the RF & LO assemblies.
What I saw was the following:
P/0 A28 RF Motherboard Assembly
A15 RF Input Assembly
Pin 21 (I) OVERPOWER (L) 3.857V
Pin 17 (E) OVERPOWER (H) 0.300V
A20 LO Control
Pin 29 (I) OVERPOWER (L) 3.856V
Pin 27 (E) OVERPOWER (H) 0.300V
pin 4 (Q) OVERPOWER PROTECT STATUS 4.58V (but jumping around)
According to Service Sheet 21 in normal operation Q16 should just be a solid high unless an overpower condition is detected. What I see on pin 4 (connected directly to the collector of Q16) is in fact a series of pulses - But they aren't a consistent train:
Probing the other pins shows a solid voltage at the measured value.
So I checked Q16 and Q28 to see if they were good and according to my el cheapo transistor checker they're both fine.
I'm at a bit of a loss to work out what the flaw is here and where to look next? If Q16 was turning on and off then I should see that reflected in OVERPOWER (H) as it drives the base of Q16 but I don't.
I do see a crappy random waveform on AMP STATUS (L) - Pin 35:
Any suggestions on where i should look next?
Thanks,
TonyG
