Author Topic: Industrial LCD display  (Read 565 times)
Offline GominaloTopic starter
« on: November 07, 2024, 04:21:20 pm »
Hi all,
I am facing to a LCD display that died suddently during weekend. I've been checking voltages and they seem to be okay, next step i think will be T-CON pcb.
Can anyone guide me through troubleshooting? (Signals to be checked, power-up sequence...)
The display is used for a semiconductor wafer prober, see photos.
Thank you.
Offline BennoG
Re: Industrial LCD display
« Reply #1 on: November 07, 2024, 05:48:21 pm »
usually the backlight breaks down on this type of units.
If you shine a bright light on the front can you see the image a little ?
Benno
Offline coromonadalix
« Reply #2 on: November 07, 2024, 05:53:50 pm »
the backlight board as 4 outputs on it, or 2 in parallel ?
check if you see markings on it, who would help you   for voltages and control pins
t-con is not for backlight ...
do i see tdk  something  on the ccfl  board   can you show us photos or write the numbers
« Last Edit: November 07, 2024, 05:56:43 pm by coromonadalix »
« Reply #3 on: November 07, 2024, 06:24:58 pm »
Benno
That has been checked by another person and told me that there's no image but i'll check by myself.
Thank you.
« Reply #4 on: November 07, 2024, 06:27:36 pm »
I supose that like others ccfl there are two tubes in series per side of the LCD that's why i have 4 connectors.
TDK S/N is: PCU-P235B
Thank you.
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #5 on: November 07, 2024, 07:06:07 pm »
Roughly a year ago i converted two old Samsung computer displays from CCFL to LED, using a kit (probably Chinese origin). After one of the displays got ready and was working well i ordered another kit and did the second one. One has to take apart the display anyway in order to fix the backlight, and the LED solution is much better: less energy consumption and less heat. Hope it will last some more years.
Regards, Dieter
« Reply #6 on: November 08, 2024, 09:26:50 am »
I've identified a bad smd component, i think it is a diode.
Before it there's only one thing, the connector wich supplies 12v directly to it, the diode is not conducting anymore. Can anyone help me identifying?
It is located in the high voltage pcb for the ccfl backlight.
Thanks.
Online inse
« Reply #7 on: November 08, 2024, 10:55:42 am »
“50“ is possibly a fuse, measure resistance across the capacitor below, it might give a hint why it blew (if it’s a fuse)
« Last Edit: November 08, 2024, 10:57:30 am by inse »
« Reply #8 on: November 08, 2024, 09:18:00 pm »
50 would be an inductance  way thicker than  the 202 resistor near it
give us the chip marking near them,  search datasheet   could give you something to work with
