Author Topic: Infi Vision MSO-X 4054A hanging.  (Read 2055 times)
Offline rtekalTopic starter
  • Country: in
« on: October 11, 2017, 05:02:32 am »
Hi
I have an Agilent Infi Vision MSO-X 4054 A oscilloscope which hangs up during startup. Following the troubleshooting guide, I found that the backlight supply and the auto probe voltages are absent. Further probing shows that the NCP3064 switching regulator looks dead. Even after replacing the IC the problem persists. THere is no signal at timing capacitor pin 3. VCC is available on switch collector pin 8. Switch Emitter pin 7 is low. On /Off pin is also low.
Has anyone faced / solved this problem Any help is appreciated.
Regards
« Last Edit: October 11, 2017, 05:16:18 am by rtekal »
Offline TheSteve
  • Living the Dream
Re: Infi Vision MSO-X 4054A hanging.
« Reply #1 on: October 11, 2017, 07:27:40 am »
At what point does it hang?
Have you connected to the internal UART to see the boot log?
VE7FM
  • Country: in
« Reply #2 on: October 12, 2017, 05:50:34 am »
After switch on Ref, Math & Digital lights glow and stays there. No Dispaly internal / external, no probe voltages.
Regards
Offline TheSteve
  • Living the Dream
« Reply #3 on: October 12, 2017, 06:24:15 am »
Sounds like it might have a flash corruption issue like the 2000/3000 series. Have you contacted Keysight to ask if they will cover the repair? If that isn't an option you will need to connect to the internal uart to see where it is hanging in the boot process.
VE7FM
Offline Zucca
  • EE meid in Itali
« Reply #4 on: October 12, 2017, 10:00:12 am »
Mine 3000X did not boot up once. then I cycle the power and no more issues...  :-//
« Last Edit: October 12, 2017, 03:16:55 pm by zucca »
  • Country: in
« Reply #5 on: October 13, 2017, 05:50:03 am »
The backlight voltage & probe voltages are not coming. Are these voltages controlled by the system? How do I check the UART signals?
Regards
  • Country: in
« Reply #6 on: October 13, 2017, 08:34:24 am »
Keysight will not cover it under warranty. They replaced the boards of 2000 series at my workplace at no cost.
regards
