Author Topic: Infrared thermometer DT-380  (Read 712 times)
Offline carrascosoTopic starter
« on: October 21, 2018, 04:21:13 pm »
Hi all.
I own a Chinese infrared thermometer DT-380 (-50ºC - 380ºC).
When going to use it did not mark well, and it did not go beyond 50ºC even if it was aimed at a flame, with low temperatures it seems to go well.
After removing the eeprom (L24C02B-SI) and erase it, the top of 50ºC was solved, but now it marks three times the actual temperature.
I ask if someone has a backup of the eeprom can you provide it to repair this thermometer.
Thanks and best regards.
