Author Topic: Insignia NS-32E400na14 TV Repair  (Read 2200 times)
Offline CommWizTopic starter
« on: March 16, 2017, 06:59:47 am »
Hey all,
I have an Insignia NS-32E400na14 TV that when plugged in, the power LED comes on, but it will not turn on (power light turns blue when working).  Has anyone had any experience repairing this model, schematics, suggestions?.  This is a three board system, Power Supply, Control/Video/Sound, Display Driver (TCON).   This TV started having this issue and could be resurrected by unplugging/plugging it back in, so I suspect the power supply.  I will be posting some pictures of the PS as soon as I get a chance to take the pictures.  The TV doesn't respond to the power switch nor the remote, and yes I have checked the batteries.  The power supply is marked well, but cannot find any schematics online.   A visual inspection of the PS doesn't show any hot spots or bulging caps or burned components, no noise(wining).   I checked voltages and it seems like most of the marked voltages are there, a couple are missing, but I'm not sure if this is due to the mode the TV is in (off).  One suspicious voltage is PS_ON and is measuring about 4.7 volts and is noisy.  There is a zener diode in this circuit a 5v6 and may be folding, hince the 4.7 with noise.   I haven't done a comprehensive suite of tests on it yet and hoped to find some more documentation (schematics) before going much further.
Any help would be greatly appreciated, thanks in advance.
Offline Rasz
    • My random blog.
Re: Insignia NS-32E400na14 TV Repair
« Reply #1 on: March 16, 2017, 07:43:18 am »
sounds like boring capacitors
Offline kingtutt
« Reply #2 on: January 19, 2020, 04:38:11 pm »
Did you ever find the issue with your TV?
I have an Insignia ns-32d511na15 and like you, cannot find a schematic.  The TV will not turn on at all.  Checked hot side of the Switch Mode Power Supply (PS) and all looks fine.  All caps look fine.  One problem I have is the power supply and main board are combined.  Would be much easier if they were 2 sep boards....then all you have to do is check the output plug on the PS to verify its operation.  Can't fine a schematic which makes it difficult.
Offline Rasz
    • My random blog.
« Reply #3 on: January 19, 2020, 10:01:03 pm »
caps look fine
doesnt matter how they look
Offline GreyWoolfe
  • NW0LF
« Reply #4 on: January 19, 2020, 10:57:38 pm »
caps look fine
I agree, I look fine but you wouldn't want to look on the inside.  Still need to check the electros.
« Reply #5 on: December 21, 2024, 03:19:49 am »
Sorry for not responding, until now.  The answer to your question is no.  I never have completed the repair and the TV has been patiently waiting for me to get a round-tu-it.  At the time, I saw a couple posts that mentioned that it's the EEPROM on the board.  I guess they become corrupted, or fail in some way.  I saw "ShopJimmy" had them for sale, so I was going to get it from him.  I never did, maybe I'll resurrect this project.  Thanks for the inquiry and let me know if you were able to repair your TV.
CW
Offline Bud
« Reply #6 on: December 21, 2024, 10:24:02 pm »
Insignia NS-32D20SNA here was fixed by replacing PS capacitors.
Shine a flashlight on the screen, turn the TV on and check if you see faint image behind the screen glass, before the TV turns itself off. If you see that then this is backlight failure, typically caused by dried caps on PS board.
« Reply #7 on: December 27, 2024, 03:33:41 am »
Thanks for the response.  I'll start checking the output caps to see what they read.  in the failure mode, the TV will not turn on, the power standby remains in stand by.  There is now a secondary issue, the button panel circuit board was broken in half a couple of years back when moving the the disassembled TV.  It looks like just a analog switch matrix so it should be pretty easy to replicate, but I would like the schematics to confirm that the resistors are all the same values.  I have the first resistor, the rest were lost over time on the other half of the PCB.  Also, during some research I found this issue listed on shop jimmy, and they said it was an issue with the eeprom on the board.  It has the expected voltage values for each of the buttons.  If this becomes corrupted, then the TV will not turn on.
Thanks again.
