Anyway, I successfully purged the chamber, no more condensation
First I connected the vacuum pump to the suction port near the power and USB connectors and pulled the air from the chamber. Then I connected Argon bottle (via the pressure regulator) to the charging port and slowly let the gas in.
You can not "overfill" the chamber, any excessive pressure will vent out through the suction port.
My camera can now reach at least 60C temperature difference, before it was struggling with 50C
