Author Topic: HP Agilent 54832B Power Supply  (Read 1845 times)
Offline edumopeduTopic starter
« on: September 29, 2016, 06:47:58 pm »
First of all I would like to say hi to you all!
I am quite a beginner into electronics and that makes my situation even worse. I have purchased a scope from eBay, an HP Agilent 54832B. Unfortunately on its trip the PSU got damaged somehow. To be more precise the +/-5V lines do not output the correct values (instead of 5V I get 05mv). Does any one has any idea if there is a replacement for this PSU (Agilent 0950-4462 Celestica 5100 Series Modular Power Supply,100-240V ,400W)? Or where I could find the schematics of it?
« Last Edit: September 30, 2016, 06:29:17 am by edumopedu »
Re: HP Agilent 54832B Power Supply
« Reply #1 on: September 30, 2016, 06:13:38 am »
Does any one knows from where I could get a schematic of the PSU? Or if some one could give me a hint about the purpose of the AUX Channel...it would be much appreciated.
Offline Lorenzo_1
« Reply #2 on: September 30, 2016, 07:56:17 am »
There looks to be a service manual at exodus.poly.edu/manuals/HP Agilent. It has some schematics + power supply diagnostics. That might help you.
