Missing pic?
Needle probes are good for working on boards with conformal coating, or poking through a wire's insulation for fast troubleshooting, or just small SMT probing.
I use
Pomona with silicone wire, good quality.
6342 is gold plated but a pogo-pin (spring end) so you can't really nail something. Cat. II 1,000V.
6275 is stainless steel tip (no spring) and I constantly stab myself. 60V only and a poor crimp connection to the aluminium tube so low ohmic readings are not great.
I have not tried low cost ones from china.
If you're poor, you can make some probes using old pens and sewing needles which are very sharp fine point. Russians do this.
For existing probes, heatshrink tubing is fine to lessen the exposed tip.
