Author Topic: Integrated circuit equivalents...  (Read 3374 times)
Offline lionelkjhTopic starter
« on: March 04, 2017, 04:50:34 pm »
Good evening everyone! Can you tell me whether the following integrated circuits are compatible and equivalent? : NJM062 (SMD) / TL062 (SMD); NJU4051 (SMD) / CD4051 (SMD); NJU4066 (SMD) / CD4066 (SMD); NJU4053 (SMD) / CD4053 (SMD). Are NJU integrated circuits Japanese made ?? Thank you for your lights :D
Offline grumpydoc
Re: Integrated circuit equivalents...
« Reply #1 on: March 04, 2017, 05:10:06 pm »
Google is your friend, data sheets for all of the ICs you mention are easy to find.
However I would assume that they are equivalent.
New Japan Radio sounds as though it should be a Japanese company but I have no idea where they make their ICs
Did you mean knowledge or insight here? (lumière in French in the sense of knowledge or understanding?).
Offline singapol
  • Country: sg
« Reply #2 on: March 04, 2017, 05:24:37 pm »
Yes they are equivalents but do check the chip package size/dimensions even if they are smd eg. SO,soic or
other package size by comparing their respective datasheets.
yes the company is japanese...NJR aka New Japan Radio corparation.
http://www.njr.com/
« Reply #3 on: March 04, 2017, 05:51:15 pm »
OK; Thanks (I am french and use google translation to speak in english in this forum, nothing is perfect!). I have, however, a doubt as to the correspondence between the NJM062 and the TL062; I looked at the datasheet, and the internal mounting of the integrated circuit is totally different, although the pinout is the same. What do you think??
Online wraper
  • Country: lv
« Reply #4 on: March 04, 2017, 05:57:54 pm »
Simplified circuits in the datasheets of NJM062 and TL062 by ST are the same, did not check others.
