Author Topic: Intel Atom desktop bootloop  (Read 7648 times)
Offline lepdenTopic starter
« on: April 28, 2017, 11:23:02 am »
I have an Intel Atom desktop here with me. It powers on immediately on connecting the power cable without me pressing the power button. It boots successfully but after sometime it shuts down on its own and after that when I press the power button it powers up for some seconds and then endless bootloop. I thought it was a short in the power button so I disconnected the power button but still the same. Now I'm guess it's a short in the power button ways in the motherboard itself. I can't see any surface mount components burt or corroded and no bulging in any of the through hole caps. How can I go diagnosing this board?
Offline Samogon
Re: Intel Atom desktop bootloop
« Reply #1 on: April 30, 2017, 06:12:59 am »
I would start looking for power rails and local regulators, also look for Vdd pins of ICs google for datasheets.
That will give you voltages required and check ripple presence.
Offline amspire
« Reply #2 on: April 30, 2017, 06:19:27 am »
When you say a "bootloop", I am not sure how far it is going, but if it is getting to the point of trying to read the hard drive, I usually boot to a Live Linux DVD or USB stick, and run it for a while in Linux. Might need the old hard drive disconnected. If it runs Linux solidly, then you know it is probably a Windows  or hard drive problem. Open a browser with lots of tabs to use lots of RAM.
If Linux crashes or has bootloops, then it could be a hardware issue.
« Reply #3 on: May 02, 2017, 05:36:14 am »
By "Bootloop" I meant, Windows shuts down normally by itself as if I've clicked the shut down button from start menu. And then when I press the power button after the shutdown, the pc powers on for 2-3 seconds- that is, no display on the the monitor, just the fan rotates and it cycles endlessly until I unplug the power cord.
Offline amspire
« Reply #4 on: May 02, 2017, 06:22:31 am »
Even if you hold the power button down for 5 seconds? That should shut it down.
Offline Samogon
« Reply #5 on: May 02, 2017, 02:23:42 pm »
Check bios settings bus speed aka overclocking can do such things. Load default settings.
Offline stj
« Reply #6 on: May 03, 2017, 10:50:06 am »
what board is it?
if it's a "Littlefalls" or "Littlerfalls2" then they are known for bad electrolytics.
« Reply #7 on: May 04, 2017, 02:19:07 pm »
I've tried resetting the bios, but no luck.
« Reply #8 on: May 04, 2017, 02:20:52 pm »
what board is it?
I'm not sure but looking at the broad label it seems the model is D945GCLf.
« Reply #9 on: May 04, 2017, 02:24:51 pm »
Yes, that is why I thought there was a short in the power button but I tried disconnecting the power button but it's behaving the same which made me to conclude that there is something wrong in the power ways on the board. But I've no idea where and how to test in the board.
« Reply #10 on: May 04, 2017, 02:52:05 pm »
It seems this pc will run longer, the longer you keep it without power. I've turned it on just now after keeping it unattended for some days and it is running for about 20 mins without a reboot. What might this mean?
Offline Samogon
« Reply #11 on: May 04, 2017, 02:57:51 pm »
Explain "without power"? Charger disconnected or shutdown for long time?
« Reply #12 on: May 04, 2017, 03:06:52 pm »
Shut down, all cable disconnected. Still running without problem. Could it be bad electrolytic as mentioned by stj?
« Last Edit: May 04, 2017, 03:09:43 pm by lepden »
Offline Samogon
« Reply #13 on: May 04, 2017, 03:17:11 pm »
Any difference if it runs with or without charger?
Overheating problem?
« Reply #14 on: May 04, 2017, 03:40:58 pm »
It's an Intel Atom Desktop.
Offline stj
« Reply #15 on: May 04, 2017, 05:17:02 pm »
what board is it?
GCLF = LittleFalls.
https://www.cnet.com/products/intel-desktop-board-d945gclf-essential-series-motherboard-mini-itx-micro-atx-intel-atom-230-i945gc-series/specs/
« Reply #16 on: May 04, 2017, 06:14:17 pm »
what board is it?
GCLF = LittleFalls.
Ok, thanks. Could you direct me to which components should I replace? Shall I just replace all the aluminium electrolytic caps on the board? Since none of it looks bulgy.
« Last Edit: May 04, 2017, 06:32:23 pm by lepden »
Offline stj
« Reply #17 on: May 04, 2017, 07:16:20 pm »
there are a bunch of GF series near the middle of the board next to some regulators/fets from memory.
GF are known to be crap and fail without external signs - they also cant take heat!
« Reply #18 on: May 05, 2017, 04:52:19 am »
Oh. You meant the four Samxon branded caps?
Offline stj
« Reply #19 on: May 05, 2017, 12:38:49 pm »
that's the ones.
i think i used poly's to fix mine - i'd need to check.
« Reply #20 on: May 05, 2017, 02:20:18 pm »
that's the ones.
Thanks man, I'll search for the parts and replace them and report back
« Reply #21 on: May 10, 2017, 08:42:27 am »
that's the ones.
I can't seem to find the exact rated caps. Could you tell me how you fixed yours? I'm pretty new to electronics so excuse me for asking but what did you mean by GF? Does mean gigafarad? If so, do you mean all 1000uf caps fail without any sign?
Offline stj
« Reply #22 on: May 10, 2017, 02:10:59 pm »
samxon GF series.
i replaced the 4 using polymer caps from Würth
1000uf 6.3v PTG5 series,
and
180uf 16v PT5H series.
« Reply #23 on: May 10, 2017, 05:49:23 pm »
samxon GF series.
and
Ok. So it's ok to replace it with a lower voltage rating? I too have some Sanyo branded 1000uf 6.3v.
Offline james_s
« Reply #24 on: May 10, 2017, 06:03:27 pm »
No, you need to use capacitors with an equal or greater voltage rating to the original parts.
