pls correct your wording, where did you take the "vanilla" expression
it's an "Intel" original or "OEM" TEK branded that's all
And for the network speed difference, i don't think it will make a difference unless you are a speed freak on capturing the scope data on lan interface ?? I do captures on GPIB port for an 7254 loll
Some board may have 80-90 % of the same components and have some hardware changes / revisions, seen that in the past, you could create more problems than solutions if you don't find the exact bios
you could take the long road to add the tek image logo in the bios etc ... etc ... and still fuck something up, checksum calculations ...
I personally would not even think or even try to mix the models bios .... just for a network hardware speed problem it seems ?
Locked ?? Yes in some bios you have flash protection enabled / disabled option. and as i written earlier, you have to crash the bios with say killcmos to make some errors and try to enter the OEM bios ... and you may loose some important settings.
Had some hard times with the 7254 after dallas chip failed, and the computer cell battery dropped low, i fucked up the screen configs pretty badly and windows was stubborn as hell to reset it
Luckily i flashed the original Intel bios.
If it works Don't touch it unless you are stubborn ??
Rename the file, if it is not ok it simply shouldn't flash
my 2 cents
some readings examples
https://forums.mydigitallife.net/threads/intel-d865gbf-board.12139/page-2
