I recently acquired an
Intel NUC DC53427HYE. I know this device is almost 9 years old
but for some headless projects it can still be of value.
there is however one big issue with the thing. It does not (
unless...) boot, and the only signs of life is a blinking blue LED once every 5 seconds.
This does seem a somewhat common issue as seen
here,
here,
here,
here and
here. The latter is even from Intel themselves. I did write a
response on such a topic to find out if the repair lasted.
To summarize what I did, I heated the board for a couple of seconds directly on the CPU/Chipset dies and when the board was still warm (
not hot) I tried to turn it on to see if that made the CPU work which it didn't. I did the same thing on the opposite side around the CPU area and to my surprise the board booted just fine. Normally I think reflow is not very worthwhile since it is most likely only temporally. But what made me curious is that the board works fine to this day (
2 days) and survived multiple (
soft)reboots. Only when I turn it off completely (
with/without removing power adapter) it goes back to its 5sec blink pattern unless I give it a hot-start.
That and since Intel mentions "
The power-on circuit may have failed" I hope that the device can be repaired.
Also this all strikes me, and reminds me of
this issue EEVblog also once covered.
I attached some pictures of the board from another forum, so they aren't mine. I forgot to take pictures when I had it open last time (
currently doing a runtime test)
I could however not find any visual sign of wear/tear on the PCB.
Kind regards (
and new member)
TimelessNL
