I bought a - correctly described as - damaged Intel Xeon E5-2699V4 (for way too much money...). It was described as "fell down, capacitor ripped out, doesn't boot". (In retrospect I don't doubt that the CPU doesn't work, but I doubt that it worked before it "fell down" - I think it was probably dead before and someone attempted a repair. Anyway - it was sold as broken and I respect it as that.)
It arrived in good shape except for the ripped out capacitors. I It looked like someone attempted a botched repair (see attached picture), so I had good hopes initially in just fixing up the ripped ground plane. There are no other visible signs of either damage or repair attempts, except for one corner that has a very little dent (which I checked to not affect the isolation between the power planes).
I measured the impedance across a remaining capacitor, and indeed, ~40mOhm (measured with 34401A in 4W mode, but including the impedance of the measurement tips). A reference measurement on a working CPU showed ~4 Ohm (unstable due to capacitor charging and strongly depending on test voltage of course), distinctively different.
I carefully cleaned up the area with a sharp knife, and ensured that there are at least no optically visible connections. But still - low impedance. I looked up the polarity from the socket pinout, and applied current, in the hope of being able to see the fault with a thermal camera. No such luck - the voltage drop across the chip is tiny (for example ~4mV at 1A), and nothing heats up significantly. I tried higher currents - after all, what's to lose - 2A, 10A, even 30A, but the voltage drop only linearly increases, indicating a resistive load somewhere.
Now I'm really confused. At that point I have pretty much given up on repair - but I'm still curious on what defect mechanism this could be. I'm not aware of a failure mode of silicon that results in 40mOhm impedance between power and ground.
I've heard of capacitors that went conductive before, but with such a low impedance? Unfortunately the huge ground plane makes it almost impossible see the effect of a tiny heatup, and the low voltage drop means that even at 30A(!!), I would only see only 3.6W of dissipated power. I removed a few capacitors (around the "impact point") that had visible damage - no change.
There is no visible damage to the ground plane, at least on the bottom.
I mapped out the voltage drop across the bank of capacitors (by measuring VCC and GND on each of the 8x13 center capacitor array), in the hope to see a local minimum pointing me to point of the shortcut, but it doesn't appear to be within the capacitors but rather outside - the voltage drops the further we go, but only a tiny bit (~4.75mV to 4.71mV). The fault must be elsewhere, and it must be freaking low-impedance.
De-lidding on this chip is difficult because the heatsink is soldered (with Indium - melting point of 156°C) to the silicon. I have no experience with de-lidding so it's a last-resort as it will likely destroy - if it isn't already - the CPU, so maybe someone has an idea?
