Author Topic: Interfacing to a CCD sensor  (Read 1158 times)
Offline AlexTopic starter
« on: March 17, 2016, 05:07:17 pm »
I have a machine vision camera that uses a CCD array, the CCD47-10 AIMO from e2v
http://www.ccd.com/pdf/ccd_47.pdf
Although the camera appears faulty, the sensor does push out analogue 'video' data. I therefore suspect the sensor is OK and there is something wrong with the readout/processing circuit.
Is there a simple way of getting an image from a standard CCD sensor to some display device?
Alex
