Author Topic: International Rectifier IR 5905 What is it?  (Read 1808 times)
Offline tru3533Topic starter
  • Country: no
« on: December 14, 2018, 06:53:49 pm »
Hello,
Trying to identify this component: International Rectifier IR 5905
Located in an Engine Control Unit
What is it? Ay idea?
« Last Edit: December 14, 2018, 06:55:38 pm by tru3533 »
Offline JKKDev
  • Country: si
Re: International Rectifier IR 5905 What is it?
« Reply #1 on: December 14, 2018, 07:29:25 pm »
I'd guess it can't be too far from this one. Look for IRF 5905 if you want to try to find the exact thing but I can't find it.
The following users thanked this post: tru3533
  • Country: no
« Reply #2 on: December 14, 2018, 09:17:04 pm »
IRF4905 is a P-Channel and 5905 can be a N-Channel? so difficult to conclude what it is
Offline JoonasM
  • Country: ee
« Reply #3 on: March 18, 2021, 02:04:09 pm »
Up!
Having probably same control unit and this IR 5905 is burnt down. I cant find any data about it except it can be IRFC5905 which is of course obsolete and informational part on Infineon site is: 55V Size 230x170 Gen 5 HEXFET CHIP PACK, Package Equivalent IRF5705.
This IRF5705 is also mysterious as I can't find any info on that one also.
Any suggestions?
Thanks!
Offline JoonasM
  • Country: ee
« Reply #4 on: March 18, 2021, 03:24:19 pm »
Hi again! I did farnell search with what I know and woopydoo there is only one option at Infineon products range:
https://uk.farnell.com/infineon/irf3805strl-7pp/mosfet-n-ch-55v-240a-to-263/dp/2839478?st=irf3805strl-7pp
Aint it nice? Only package available is correct TO-263 aka D2PAK with relatively low resistance and heavy duty 240 A of current lifting which sure does this heavy lifting excavator do :D
And most importanly isn't this coincidence in the end there 5905 -> 3805
Well I hope I'm right! I hope to post it here how did it go.
Offline lukipl
« Reply #5 on: October 27, 2022, 09:44:21 am »
Hello tru3533,
Did you solve the problem? What MOSFET did you use?
Or maybe someone has photos of this plate from the bottom. I have a damaged measuring resistor. It is in the middle of the plate near the transformer
Offline fzabkar
« Reply #6 on: October 27, 2022, 05:34:07 pm »
Check out the 1994 product catalogue (page 65 onwards):
https://mirrorservice.org/sites/www.bitsavers.org/components/internationalRectifier/
"SMD-220" is a similar looking package style, but I don't know its dimensions.
Could "519C" be the part number rather than "5905"? (probably not -- other IR devices have the part number on the top line)
The part numbers in the catalogue would suggest that "5xx" corresponds to a 100V device. The "C" appears to indicate "low charge". A "9" prefix indicates P-channel.
« Last Edit: October 27, 2022, 05:56:03 pm by fzabkar »
