Author Topic: Intertek S003IV0600050 - Unknown IC SOT-25 PB07  (Read 1264 times)
Offline semiRocketTopic starter
  • Country: hr
« on: May 24, 2018, 09:10:59 am »
I have a wall adapter Intertek S003IV0600050 that doesn't give any output voltage. By investigation, switching IC seems to be dead (Only 7 ohms between Pin 1 and Pin 2). The only issue is I can't find any information on this IC and possibly a replacement part for it.
What I found out by tracing on PCB.
Pin 1 - VCC
Pin 2 - Ground
Pin 3 - Sense on the output possibly
Pin 4 - Emitter of the main switching transistor
Pin 5 - Base of the main switching transistor
Offline Gall
  • Country: ru
Re: Intertek S003IV0600050 - Unknown IC SOT-25 PB07
« Reply #1 on: June 09, 2018, 10:24:22 pm »
It might be iW1676.
« Last Edit: June 09, 2018, 10:27:13 pm by Gall »
The difficult we do today; the impossible takes a little longer.
