Author Topic: Inverter with shorted output cap  (Read 271 times)
Offline St3venAU
« on: September 16, 2019, 04:06:30 pm »
I have a 12VDC to 240VAC inverter that has a failed (shorted) output cap. It’s a 0.01uF cap rated for 400VDC. I was wondering if since this cap is across the AC output of the inverter, wouldn’t it make sense to use an AC rated cap instead of DC?
Do you guys think that this (https://www.altronics.com.au/p/r3102a-0.01uf-x2-pcb-mains-suppression-capacitor/) would be a suitable replacement, or should I stick with a 400VDC rated cap?
Original Cap:
Offline james_s
Re: Inverter with shorted output cap
« Reply #1 on: September 16, 2019, 04:23:12 pm »
Typically film caps are good for ac or dc, typically the dc rating will be higher. I'd use one soecifically rated for ac though, cheap capacitor may be why it failed.
The following users thanked this post: St3venAU
