Author Topic: Is it possible to crimp Molex Mini Spox without experience in crimping?  (Read 908 times)
Offline M_a-r_k-u_sTopic starter
Hello everyone,
I want to crimp cables (Molex Mini Spox) to repair a robot. Since I have no experience with crimping, I wanted to ask here if it is possible to do it successfully without having it done before. Because the crimping pliers from Molex costs 400 bugs or so and I don't want to waste the money. I just saw that Molex offers also pre-crimped cables, but to maximum length of 450mm, which is not enough.
I have some links to the plier and socket in case you don't know Molex Mini-Spox:
https://www.digikey.de/de/products/detail/molex/0008701040/259393
https://www.digikey.de/de/products/detail/molex/0638281900/7400393
Thank you,
Markus
Online inse
Re: Is it possible to crimp Molex Mini Spox without experience in crimping?
« Reply #1 on: December 26, 2022, 04:18:58 pm »
This is rather flimsy stuff.
If you need proper strain relief I would recommend to extend pre- manufactured cables.
Online wraper
  • Country: lv
« Reply #2 on: December 26, 2022, 04:25:48 pm »
You do not need experience for crimping. It's very easy do right if you have a proper tool. Just watch some video how it's done to be sure you do everything properly.
Online wraper
  • Country: lv
« Reply #3 on: December 26, 2022, 04:27:39 pm »
Frankly your post makes no sense, please elaborate.
Online inse
« Reply #4 on: December 26, 2022, 06:07:29 pm »
The proper tool is €400, so soldering extensions to pre-manufactured cables makes probably more sense.
As with hobby tools you will not get a reliable crimp.
Offline tooki
« Reply #5 on: December 26, 2022, 06:31:15 pm »
Hello everyone,
The Mini-SPOX contact isn’t too demanding on the tool, compared to some connector types. The ~$25 Toozo TZ-4228B (aka SN-4228B, etc) from aliexpress does a pretty good job on it. (I just tested it, using the second-smallest die opening, and it came out quite well, fits into the housing, and seems to pass an unscientific pull test.)
Molex sells a cheaper crimp tool, the https://www.molex.com/molex/products/part-detail/application_toolin/0640160201 which is officially for the Mini-SPOX (among others) that costs about $150 on Digi-Key. We got one at my old job and weren’t super impressed by it, but Digi-Key refunded the money (without even wanting the product back!) without any questions, so it’s something you could try out. Maybe you’ll receive one that was a bit better than what we got. But the $400 tools are much, much easier to use.
You could consider buying pre-crimped leads and extending them with soldered splices.
The following users thanked this post: wraper, M_a-r_k-u_s
Offline Ian.M
« Reply #6 on: December 26, 2022, 06:58:19 pm »
Tooki has put more effort into testing crimpers than many hobby users have into using them! See: https://www.eevblog.com/forum/reviews/affordable-crimp-tools-for-small-connectors-(dupont-etc-)/
