hey eevblog people,
I have an old sony video-8 ev-s1 here that belongs to an elderly neighbour and it has a dead power supply, i've tried to find schematics or any data / pictures to help online but nothing useful so far.
The unit has sentimental value to the neighbour and he would like to see it up and running again if possible.
Anyhow, apart from the leaky capacitors that have ate away some of the board I can identify all the components and should have suitable substations for testing except for a zener diode that goes across the secondary of the transformer, it was burned in half so identifying it is out of the question, I assume it is a zener as the silkscreen on the pcb is a diode symbol with diagonal arms. (It runs from just below pin 7 of the transformer in the attached image)
I'd like to try and get the powersupply up and running so I can see if the actual VCR part of the deck is still functional, usually for something important i'd try and track down another identical unit to compare / swap the part or take measurements but even that is proving difficult.
So what i'd like to know is if there is some kind of power supply theory that will allow me to make an educated guess at what value diode was in there?
thanks in advance for any pointers
