Author Topic: Is it possible to modify TC Nove System to Work with 4cable method ?  (Read 842 times)
Offline fenderenderTopic starter
  • Country: tr
Hello guys, I'm after modifying a TC Nova System.
I think it can be possible to break the link between analog drive part and digital effetc and adding a send and a return jack
in between. Anybody did this before ?
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
Re: Is it possible to modify TC Nove System to Work with 4cable method ?
« Reply #1 on: February 21, 2017, 11:46:49 am »
I think so - though I have not done it.
J2 holds the analog signals if I remember correctly. I believe a dry and wet signal is available there.
Put an audio signal into the unit and probe J2. Volume and Gain are done on the board, Tone and Boost are done on the main board digtally...
Hope it helps.
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
