Its an edge backlight monitor. You will probably have an LED strip on the bottom, and there will be a bunch of lens on them, connecting it to the diffuser layer. I dont think you will need to peel off anything to fix it. Basically the panel likely can stay in one piece.
Besides, what do you have to loose, other than your time?
