So I'm taking a look at an engine ECU that's had 24v into it.
Three of these capacitors were showing as shorted, and once removed and checked out of circuit, it was confirmed.
My first thoughts were just to get another three of these capacitors, solder them back and see if things improve.
I've got a yellow square with 333K on it, and to me, that means 33nF, 10% Tolerance, tantalum.
Looking around, I can't seem to find SMD tants in 33nF, and also there's no polarity marking on them either, so I'm starting to question what these actually are.
This was out of engine electronics from the late 90s, and I've since spotted another "333K" marked yellow square in a more modern 2010 engine ECU, also with no polarity marking.
Mouser, RS, Farnell, Digikey etc only have 33nF Tantalums as axial, so have I just assumed its gender because it's yellow?!?
