Author Topic: is rice method safe??  (Read 17748 times)
Offline aqarwaenTopic starter
« on: January 06, 2017, 10:01:58 pm »
i accidentally droped tea mug,with hot tea.into my my macbook air 13.i noticed some tea water got into my macbook ,so i instanly turned it off.is rice method safe to use,to get all tea water out my macbook?its not under warranty.i read that some people recommend or even some famous youtuber even use it.
« Last Edit: January 06, 2017, 10:05:15 pm by aqarwaen »
Offline grifftech
    • youtube channel
Re: is rice method safe??
« Reply #1 on: January 06, 2017, 10:05:13 pm »
yes
Offline ataradov
    • Personal site
« Reply #2 on: January 06, 2017, 10:06:26 pm »
Yes, add rice and boil until cooked.
It is as safe as it is pointless.
BTW, if you have not unplugged the battery until now, your macbook is a toast by now if water actually got inside. Turning it off does not necessarily help a lot, standby circuits are still under voltage.
« Last Edit: January 06, 2017, 10:08:15 pm by ataradov »
Alex
The following users thanked this post: MK14
Offline MK14
« Reply #3 on: January 06, 2017, 10:21:19 pm »
MAC-AIR-oni (Cheese) on toast, with some RICE and sliced APPLE. Should taste really nice, with a nice hot cup of TEA (which you have already added  :-DD).
Hopefully remove all power sources (all batteries), thoroughly clean with safe substances, and allow plenty of time to be absolutely dry before ever powering up again. Else it may destroy itself with electrolysis.
« Last Edit: January 06, 2017, 10:22:58 pm by MK14 »
Offline mariush
« Reply #4 on: January 06, 2017, 10:29:01 pm »
Take a few minutes to watch this:
So true.
The following users thanked this post: TiN, tooki, MK14
Offline RGB255_0_0
« Reply #5 on: January 06, 2017, 10:31:59 pm »
So true.
Well he should take the laptop apart (or take it to somewhere who can) and disconnect the battery first, then watch the video.
Your toaster just set fire to an African child over TCP.
Offline Johnny10
« Reply #6 on: January 06, 2017, 10:36:58 pm »
If rice works then why not cat litter.
Yikes !!
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
Offline chickenHeadKnob
« Reply #7 on: January 06, 2017, 10:44:11 pm »
There is something in black tea that corrodes the hell  out of pcb traces and keyboard contact pads. I don't know if it is the tannins or what. Disassemble and flush with water right away. I have wrecked 2 keyboards that way. It surprised me the first time as I thought tea was fairly benign.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #8 on: January 06, 2017, 11:06:30 pm »
I've heard rice works well but never had the need to use it, one thing I will say though is that last summer I boiled up some rice in preparation for a stir fry which we have often, anyway on this particular occasion for some reason I didn't give the used rice pot a wipe out and rinse which I would normally do prior to doing the dishes and left it on the bench over night, the following morning I came out into the kitchen to make the coffee and found two black house spiders, one white tail spider and some other unidentified creature all having breakfast in the rice pot. I could only assume from that particular experience that they are attracted to the smell of cooked rice so we have been pedantic ever since in not leaving invitations like that around.
Spiders suck.    :scared: :phew: :--
Offline BradC
« Reply #9 on: January 06, 2017, 11:15:11 pm »
I keep a couple of kilos of silica gel around for just such occasions. Rice is a bit of an old wives tail that harks back to putting rice in the salt shaker to stop it caking. That was a mechanical process, but people believed the rice absorbed water in preference to the salt.
I also have a big pot with a silicone seal I use with calcium chloride. That will suck the moisture out of silica gel, but it's a one time affair. Cheap enough though.
Right tool for the right job.
Offline Fraser
« Reply #10 on: January 06, 2017, 11:15:16 pm »
Rice is a total waste of time and just contaminates the equipment further.
To be aware, some computers have non removable main batteries now :(
Also many laptop designs use a separate battery to provide power to the RTC etc. If there is a battery of any sort connected to the PCB, electrolytic action will normall start eroding pins of components that are powered.
A laptop that has had a 'bath' should be disassembled and at least inspected and cleaned by a competent person knowledgeable in fluid damage repairs on computers. Speed is of the essence. Do not wait a few days to get it disassembled and cleaned.
Fraser
The following users thanked this post: tooki, MK14
« Reply #11 on: January 06, 2017, 11:34:07 pm »
Mutt's that I've had over the years would roll their lips back when they encountered any critters that might nip them back, try that attack Muttley.  :)
  • Cursed: 679 times
« Reply #12 on: January 06, 2017, 11:56:00 pm »
As you well know, generally around here it's the chainsaw that is best suited when dealing with these big black hairy monsters. Anyway, as she who regularly takes them out back always says objects may appear larger whilst idiots are wearing empty coke bottles.   ::) :P
 :horse: :box:
« Reply #13 on: January 07, 2017, 12:04:37 am »
 :horse: :box:
She......that is scared of such things thankfully can't use a chainsaw (I've a few) but she can use a shotgun....one of the reasons why I keep them locked away.  :scared:
Offline Moshly
  • What's wrong with this thing
« Reply #14 on: January 07, 2017, 12:13:50 am »
I heard that it is suppose to be boiled rice that has been baked dry.
Apparently used to keep film stock viable in the jungle during the Vietnam war.
The following users thanked this post: MK14, JPortici
Online tooki
« Reply #15 on: January 07, 2017, 12:23:09 am »
No. You wanna rinse away all the tea before it has a chance to cause corrosion — the rice method simply delays this crucial step. (See the first video.)
  • Cursed: 679 times
« Reply #16 on: January 07, 2017, 01:02:09 am »
Louis Rossmann in agreement with the first video also concluded that the rice drying method does more harm than good by not immediately and properly addressing the issue in addition to possibly leaving harmful residue, definitely some good advice to be had here.
Offline Inflex
    • Charters Towers Phone & Computer Repairs
« Reply #17 on: January 07, 2017, 02:12:10 am »
Yep, I'll be concurring with Louis's point of view.  I've received many machines and phones that have rice in them after several days of corroding away (phones especially!).  The whole rice myth is resulting in a lot more damaged equipment than there needs to be.
For me though, the greater peeve is when people choose not to honestly tell me that it's been dropped in a [dirty] toilet, good reason to suit up and have a big container of IPA on the ready - damned biohaz :(
Magicsmoke abuser | What I repair daily on YouTube | FlexBV
- BoardView
| Paul Daniels
Offline SpaceCow
« Reply #18 on: January 07, 2017, 08:46:06 am »
I've watched this video before, and I didn't understand it then. I'm glad have the opportunity to question it now. Louis acts like people believe that rice is somehow going to magically heal corrosion damage on the phone. I don't that anyone believes that beyond a few real dummies.
I thought that the idea of surrounding the device with rice and putting it in a dry place is that the rice helps absorb the water/humidity from the phone, as rice does function as a desiccant to some extent. Therefore, the point of the rice is an attempt to dry the device as quickly as possible if water gets inside the phone or perhaps stuck behind the display. The reasoning is that the faster the water is removed from the device, the less corrosion occurs.
I understand that Louis and others are frustrated from dealing with stupid customers all the time, but it seems insulting their intelligence to act as if they believe sticking rice on corrosion is going to heal a phone. No one thinks that or ever thought that. The rice reasoning was an attempt to remove water from the phone as fast as possible and prevent corrosion damage. I'm not saying that there aren't better ways to do that, though because there are. However, the desire to remove the liquid from the device is complete rational and is "denial" or the belief in magic. The sarcasm that always accompanies this topic seems unnecessary and a bit demeaning.
What do you guys think? Am I missing something here?
« Last Edit: January 07, 2017, 08:47:54 am by SpaceCow »
Offline ataradov
    • Personal site
« Reply #19 on: January 07, 2017, 08:55:55 am »
That is the kernel of truth in this urban legend.
The problem is that rice is not a good desiccant. Not at all.
It is like saying: "jet propulsion works, so if I eat a can of beans, I should be able to fart my way to the moon". The principle is correct, but magnitudes of effectiveness are not even close.
Even real silicagel is not going to be super helpful in this case.
« Last Edit: January 07, 2017, 08:57:44 am by ataradov »
Alex
Offline Inflex
« Reply #20 on: January 07, 2017, 09:09:47 am »
   It's a bit of an inside joke as it were, with a lot of satire / sarcasm heaped on for effect.   No, Louis doesn't believe that people believe that it magically heals things; it's just over-the-top drama for comic relief of others in the industry to watch.   I'm sure if you were to ask seriously, he'd agree that most people simply believe that rice will dry out their equipment to the point where it works again.
   Essentially that it's humour/blow-off borne of frustration that runs with the industry; likewise you'll find the same sort of thing among mechanics, doctors, architects.
- BoardView
| Paul Daniels
Offline SpaceCow
« Reply #21 on: January 07, 2017, 09:44:07 am »
I guess the joke went over my head. Thanks for setting me straight.
Offline bsalai
« Reply #22 on: January 07, 2017, 12:53:47 pm »
Listen to Brad. He has got it right.
Sent from my iPhone using Tapatalk
Brad, W2EK
Offline Inflex
« Reply #23 on: January 07, 2017, 01:09:47 pm »
I keep a couple of these rechargable silica gel drying blocks handy, just for pulling out the last bits of moisture from items by sealing the phone/board in with the silica gel  in a small container for 24hrs or so.
No good if it's sopping wet, but good for after you've already washed/dried it off as much as you can and just want to get those last bits.
- BoardView
| Paul Daniels
Offline Seekonk
« Reply #24 on: January 07, 2017, 01:17:04 pm »
Nutting says lovin like something from the oven.  Just take the battery out and stick it in the oven, should you have something other than a microwave, on a low temperature setting like proof (120F).  My wife has hearing aids and they supplied her with something like a coffee cup warmer to put them on.
