The UV sensor appears to have a glass over it, I couldn't see clearly but it appeared like there is a thin crack is on the glass, inside the glass I can see a squiggly trace. Two wires from this go to a 6-pin wire connector, I cannot detach those wires and I cannot desolder the UV sensor, the only option is I have to cut the wires, Is there a way to check if this UV sensor is working or not?
