Author Topic: Is there any way to fix a shorted arduino?  (Read 3391 times)
Offline abdullahsebaTopic starter
« on: July 25, 2015, 05:32:09 pm »
I shorted the GND and 5V pin together by accident GRRRR |O |O |O |O |O |O |O :-[ :( :-[ :-[ :( :(
This is my right hand this is my wrong hand
Offline pattyrice
    • DoublEElectronics
Re: Is there any way to fix a shorted arduino?
« Reply #1 on: July 25, 2015, 05:57:22 pm »
What Arduino is it?
Have you checked for holes in any of the components?
The on-board regulator can be replaced or the whole micro if you got the tools. Unless it is a really expensive one, it might be beyond economical repair (BER).
Offline bookaboo
  • Country: ie
« Reply #2 on: July 25, 2015, 06:05:29 pm »
That shouldn't actually break any decent voltage regulator. Post pics, schematic and more details if you want detailed info. But as above unless you fancy the challenge of the repair the best route may be to buy new.
Offline Seekonk
« Reply #3 on: July 25, 2015, 07:58:38 pm »
Have you tried it again after it cooled down? If regulator shot, it can also be powered externally with 5V.
Offline ivaylo
« Reply #4 on: July 26, 2015, 06:51:25 am »
I've done exactly that by accident and all it did was burn a trace, which you just fix with a bodge wire...
« Reply #5 on: July 26, 2015, 08:56:11 pm »
What Arduino is it?
Sorry Arduno MEGA 2560
« Reply #6 on: July 26, 2015, 08:57:22 pm »
I will try this
« Reply #7 on: July 28, 2015, 04:12:31 am »
Thanks I tried it and it works :-+ :-+
