I did a small batch of QFNs with solderwick, maybe 30-50 of them. I set the chips upside down on FR-4 and apply liquid rosin flux. This flux prevents the chip from sticking and lifting with the solderwick. I might have even glued them to the board with hot air, to dry the flux. Then after they're all done, I had to scrape the chips off the FR-4 with a chisel. Then I laid them on a paper towel with alcohol, and fold the towel over and rub them around in it. IIRC, I ended up making a little "bag" of paper towel wetted with alcohol and shook them around for the final cleaning. I salvaged just shy of 2 bucks a chip, so maybe 50-75 bucks for an hour of work.
