Author Topic: Is this a 4-pin transistor?  (Read 3960 times)
Offline DeckertTopic starter
    • TechBench
« on: September 20, 2020, 01:49:41 pm »
I am restoring this old FM transistor radio for my father. It looks like the RF input amp stage got damaged due to a static discharge on the antenna (that's the description I got). I'm guessing it dates from the early 1970's or late 60's. The audio-amp section seems to be working fine (can inject a tone and it's loud and clear on the speaker).
The tuner itself also seems to work (can measure the tuning frequency on the back of the variable cap-set), but it's just not picking up anything at all.
The antenna feeds directly into this four-pin device via a cap - I suspect that's the culprit.
It's labeled "121", but there are other devices - most are labeled "123" and some are labeled "125". Any idea what these devices are? (Four-pin transistors, perhaps?)
--deckert
« Last Edit: September 20, 2020, 01:52:46 pm by Deckert »
Online PA0PBZ
Re: Is this a 4-pin transistor?
« Reply #1 on: September 20, 2020, 02:53:52 pm »
Did you check the bottom side? Maybe 2 pins are connected.
Edit: I think I found it: https://www.donberg.ie/catalogue/bf_121.html
« Last Edit: September 20, 2020, 02:59:10 pm by PA0PBZ »
The following users thanked this post: Deckert
Online coromonadalix
« Reply #2 on: September 20, 2020, 02:58:22 pm »
seems an rf transistor ??  or somekind of an amplifier    cant recall their name     maybe  mar   something ??
EDIT  loll beaten  while writting this    :-+
« Last Edit: September 20, 2020, 02:59:59 pm by coromonadalix »
Online Wallace Gasiewicz
« Reply #3 on: September 20, 2020, 03:30:33 pm »
Two pins could be connected. Either internally or visibly, PAOPBZ is probably correct.
Incredible that he found documentation.
But the "S" pin might be the case (maybe there is one inside the plastic) and not connected to the transistor itself. Check if it is connected to ground maybe. Maybe it is just there for mechanical stability in mounting?
This is really old and probably from the 1950s.
Newer pill type transistors like some GaAs (microwave stuff) have the two side pins common, emitter leads, I believe.
They look a lot like your transistor.
This MIGHT be similar in it's connections. Maybe top and bottom are connected.
Offline bdunham7
« Reply #4 on: September 20, 2020, 03:56:14 pm »
A schematic of a different radio using these shows a fourth terminal connected to ground.  I don't know what an 'S' means in German in this context.
https://www.radiomuseum.org/tubes/tube_bf121.html
Offline schmitt trigger
  • Country: mx
« Reply #5 on: September 20, 2020, 04:04:43 pm »
Several of the early RF/IF transistors had a shield terminal in addition to the CBE terminals.
The shield was commonly grounded.
An example I am familiar with is the AF126:
https://m.electronic-spare-parts.com/descript/a/af_126.htm
« Last Edit: September 20, 2020, 04:08:40 pm by schmitt trigger »
« Reply #6 on: September 20, 2020, 04:08:16 pm »
Maybe
Shield = Schild (Ger)
Posted before i read the previous post
« Last Edit: September 20, 2020, 04:11:52 pm by Wallace Gasiewicz »
Offline Twoflower
« Reply #7 on: September 20, 2020, 04:09:41 pm »
The S pin is probably the substrate. Some transistor designs don't have the collector 'on the backside' of the crystal.
Offline drussell
  • Hardcore Geek
« Reply #8 on: September 20, 2020, 05:33:13 pm »
Many early transistors had a connection to the substrate brought out to a pin.
Offline eurgenca
  • Country: si
« Reply #9 on: September 21, 2020, 03:16:57 pm »
Normally replaceable-slightly different:
  BF153 ; BF198 ; BF310
Regards.
Offline amyk
« Reply #10 on: September 22, 2020, 12:07:04 am »
Datecode on speaker says 13th week of 1971.
Later electronics would be higher density, earlier would not have that style of electrolytics.
The following users thanked this post: shakalnokturn
Offline vk6zgo
« Reply #11 on: September 22, 2020, 04:20:01 am »
Certainly not 1950s as someone said!
That style of transistor package was around in the late '60s, but not before.
From the spec sheet, I would think the "S" pin is probably "screen".
This terminology was used for the pin connected to the metal case on a lot of transistors.
The plastic package may have an internal equivalent.
Of course, the exra pin might just be used for more secure mounting.
Offline james_s
« Reply #12 on: September 22, 2020, 05:06:49 am »
I have seen dual gate FETs with 4 pins in radio gear but it doesn't look like that's what this is.
Offline paschulke2
« Reply #13 on: September 22, 2020, 06:05:07 am »
BF121 is a late 60ies silicon RF-Transistor, typically used in IF amplifiers. And: Yes, the device shown in the photo is a BF121.
S = "Schirm" = Screen.
This was taken over from the germanium RF transistors, e.g. AF124, in the metallic TO-72 case, where "s" is simply connected to the case.
"S" is typically connected to ground.
« Last Edit: September 22, 2020, 06:44:26 am by paschulke2 »
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #14 on: September 22, 2020, 11:40:20 am »
The datasheet mentions for the RF parameters "Abschirmung auf Emitterpotential", so I suspect that "S" is commonly connected to "E", whatever that is connected to. Frequently you'll find a "common base" amplifier in RF or IF stages, so E is not necessarily GND.
Offline paschulke2
« Reply #15 on: September 22, 2020, 01:30:30 pm »
… so E is not necessarily GND.
That's why S is not internally connected to E, B or C.
Here's an example: Bang & Olufsen Beolit 500
TR1 and TR2 are BF115 in a 4-pin TO-72 case. "S" is drawn as a screen in the schematic and is connected to ground. RF amplifier (TR1) and oscillator/mixer are both common base.
TR3, 4 and 5 are BF121. "S" is drawn as a screen in the schematic and is connected to ground through 47nF capacitors. These IF amplifers are common emitter amplifiers.
Edit: Quote from the Intermetall datasheet for the BF125: Die Schirmelektrode ist hochfrequenzmäßig zu erden (The screen electrode must be grounded for RF).
« Last Edit: September 22, 2020, 01:43:20 pm by paschulke2 »
Online PA0PBZ
« Reply #16 on: September 22, 2020, 01:45:59 pm »
I see a connection between the emitter and the shield on all three.
Offline paschulke2
« Reply #17 on: September 22, 2020, 01:56:06 pm »
 … outside the transistor, which is normal for a common emitter RF amplifier.
But I give up. Oh … wait … what do you see for TR1 and TR2? Is the screen connected to the emitter? Would a common base RF amplifier work with a grounded emitter?
