Author Topic: Tektronix DPO4034 repair (encoder with broken pan/zoom shaft)  (Read 2278 times)
Offline JwallingTopic starter
  • This is work?
« on: September 12, 2018, 04:11:22 pm »
So I have a Tek DPO4034 that has a broken shaft on the pan/zoom control. The encoder is quite complex and it cannot be repaired. I explored drilling the shaft down the center and using a screw, but it's not built in such a way where that's possible at all.
I'm not sure if this is a custom part or not; I suspect that it is, but I'm hopeful that it's not.
The only marking on it is J07J28. At least I think that it's a zero.
Has anyone ever seen one of these encoders or know who the manufacturer is, or whether it's custom made for Tek?
I'm pretty sure that Tek will not sell the part, and offer only a replacement board for big bucks. These days, I guess they figure if soldering is required, the end loser can't fix it...
Thanks!
Jay
System error. Strike any user to continue.
Offline pbarton
Re: Tektronix DPO4034 repair (encoder with broken pan/zoom shaft)
« Reply #1 on: September 15, 2018, 08:04:20 pm »
I bought a TDS3014B with a broken encoder shaft. I managed to buy a damaged TDS3014B PCB with all the encoders in place. The shaft part of the encoder was attached to the PCB with 'hot melt' plastic rivets. So, its not difficult to remove the shaft half of the encoder. The other half of the encoder is actually part of the PCB. I swapped over the plastic encoder and the problem was fixed.
Here is a relevant patent......
http://www.google.com/patents/US6542089
and Tektronix supplier is here....
http://www.bourns.com/products/encoders/contacting-encoders
Tek sources from Bourns with the condition that Bourns are restricted to Tek sales. So these parts are proprietary, you will not be able to source the individual encoder.
Your best chance is to find somebody who is parting out a DPO4034.
  • This is work?
« Reply #2 on: September 16, 2018, 09:29:07 am »
As an alternative option you can model the part and 3d print a replacement.
I don't have the resources for that, unfortunately. Also the shaft is missing...
I may end up buying a DPO2012 front panel from Tek. They want $252 for it!
Jay
  • This is work?
« Reply #3 on: September 18, 2018, 09:48:06 am »
If you do the modeling I would be happy to print it for you. Basically no filament goes into this since it is so small. During my printing down time or color changes I would be happy to knock one out for you.
As I said, I don't even have a part to model from, and, additionally, don't have the software or knowledge to do it anyway. I do appreciate the offer, though...
I'll probably bite the bullet and buy a DPO2K front panel PCB from Tek. $252 - ouch.
Jay
Online coromonadalix
« Reply #4 on: September 18, 2018, 10:32:53 am »
have you tried to ask for an part number at tektronix ??? or if they have an part left ???
well :  :(
this link doesn't show the encoder as a separate part ???
https://doc.xdevs.com/doc/Tektronix/Tek%20DPO%2C%20MSO%204000%20Series%20Service.pdf
« Last Edit: September 18, 2018, 10:35:24 am by coromonadalix »
  • This is work?
« Reply #5 on: September 18, 2018, 11:00:21 am »
well :  :(
Yes, I have contacted them in the last week. They don't sell any component-level parts for these. Only assembly level parts can be bought. Sucks as they are a high failure part as evidenced by all the broken ones I've seen on Ebay. The damn knob sticks out so far, and the shaft is hollow at the base. A pretty flimsy design...
When I replace this one, I'll try to remember to follow up with some pictures of the internals.
Jay
