Hi Guys,
Thanks for the replies.
The DOS1102 is newly arrived (discount deal from Amazon, seemed too good to pass by), so is on probation you could say. And, yes, my first thought was that this was some artefact of the scope.
I have an old analogue scope here also, but these 'spikes' just don't show up, although it will trigger randomly when set above the main signal level, so my feeling is they are there. I also have a boat anchor valve sig gen that I can generate much the same kind of modulated signal and this displays fine on the digital scope.
And yes, I can set the DOS1102 to trigger just of the spikes - see pick with distorted waveform.
So my feeling is they are real.
On a whole different topic: I have noticed that the DOS1102 does have a kind of aliasing issue on signals below around 2MHz (see second photo), one click lower in time/div and it displays fine. But maybe digital scopes can have this effect? Not used one before.... And I think I could probably live with it....
