1-Propanol and ethanol are primary alcohols and are more acidic (as proton donors) than 2-propanol (isopropyl alcohol). The reason is that methyl groups are viewed as electron donors, and the carbon to which the OH group in 2-propanol is attached has two; whereas, in ethanol and 1-propanol, a single methyl or methylene (-CH2-) group is attached to that carbon. Loss of a proton from an alcohol leaves a negative charge on the oxygen. Electron donors make that less stabilized (i.e., less favored) compared to the weaker effect of a single methyl or methylene group. Ethanol is used safely to remove soldering flux.
Think of it this way, none of those 3 alcohols is more acidic than water, and PCB's get washed in water all the time.
1-propanol will evaporate a little more slowly than 2-propanol, and I don't like its smell as much. There may also be a slight difference in solvent power for flux reside, but probably not anything you will notice.
EDIT: It will be fine with solder resist and probably no worse than 2-propanol for any conformal coating. There are different types of conformal coatings.
