Hi guys,
I recently acquired a Fluke 79 III that was going to be discarded, and I've noticed a few issues. The range and yellow hold buttons don't work properly. Sometimes, the hold button works when I press hard enough. I took it apart to have a look, and the contacts seemed to be in good condition. I used a small metal rod to trigger the contacts, and indeed it worked, but it was also failing intermittently. My concern is that the issue might be deeper within the electronics.
I have attached a few pictures. I would greatly appreciate any tips from you guys.
