Author Topic: Issue with Uni-T UT210E clamp meter  (Read 3236 times)
Offline EngPhoeNIXTopic starter
« on: October 08, 2018, 07:36:14 pm »
Hi Every one,
I get a brand new Uni-t UT210E clamp meter from Aliexpress , once I power up the meter , I get "CAL" on the display , as shown below :
https://www.photobox.co.uk/my/photo/full?photo_id=501131967326
Then is followed by random numbers also shown on the display , some sort of counting numbers in hexadecimal form :
https://www.photobox.co.uk/my/photo/full?photo_id=501131969064
Then showing error message " err1" as below :
https://www.photobox.co.uk/my/photo/full?photo_id=501131968129
& then the device is not responding to any key & hang up , if I pressed the select button several times  while the numbers counting I can get the meter ready to measure according to the dial selection , but I doubt it will give the correct measurement , also at that time the hold button do nothing & I can not get the back light operation as well , does any one face this situation with this meter ? does any one can help to fix this issue ?
Thank you.
« Last Edit: October 08, 2018, 07:46:30 pm by EngPhoeNIX »
Offline JohnPen
Re: Issue with Uni-T UT210E clamp meter
« Reply #1 on: October 09, 2018, 09:06:43 am »
First thoughts are to replace the batteries just in case they are they or their contact resistances are causing problems.  Otherwise there is a long thread about the UT-T-210E on EEV that may help as well.  Unfortunately it could just be a dud and needs to be returned.  Best of luck.
https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/
John
« Reply #2 on: October 09, 2018, 06:50:02 pm »
John
Thank you for your reply , I changed the batteries with new ones but still the same issue .
Offline alex27riva
« Reply #3 on: June 06, 2021, 08:54:29 am »
Hi everyone, I have the same problem with my clamp meter, is there any way to fix?
Offline Qw3rtzuiop
« Reply #4 on: June 06, 2021, 09:44:41 am »
Your meter is in the calibration mode.
Its described in this post: https://www.eevblog.com/forum/testgear/a-look-at-the-uni-t-ut210e/350/
