Author Topic: Repair to damaged front panel of Datron 4808  (Read 1846 times)
Offline perdrixTopic starter
« on: April 02, 2019, 02:59:51 pm »
Before I acquired my 4808 it suffered damage to the front panel
Has anyone experience of repairing this type of damage, and if so what products will do a good job?
Thanks lots
Offline dnwheeler
Re: Repair to damaged front panel of Datron 4808
« Reply #1 on: April 02, 2019, 03:36:40 pm »
Check out this YouTube video for a more extreme case (a shattered Atari 800XL):
The results aren't great, but your case is much simpler. The basic idea is to create a mold of the texture (from a good area), then use that and fill it with epoxy to replace the missing area. Then finish and paint as desired.
Offline branadic
  • Sounds like noise
« Reply #2 on: April 02, 2019, 03:47:52 pm »
If you don't want to fix it, but replace it you could reconstruct the panel in a CAD program and send the CAD file to a chineese company to make a vacuum PU mold, a 3D-printed part both including textures or a cnc machined aluminium part and powder coat it, which should give similar results of the surface.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline pbarton
« Reply #3 on: April 02, 2019, 08:48:14 pm »
I have never used it myself, but I have heard of good results using 'Sugru'.
https://sugru.com/
Online coromonadalix
« Reply #4 on: April 03, 2019, 01:22:19 am »
Sugru +1    you can slowly sand it, and fit it to your frame,  when its dry
« Reply #5 on: December 14, 2019, 01:05:59 pm »
I sprayed the opposite corner of the panel with "mould release agent" and then applied silicone sealer in an attempt to make a negative mould.
It appeared to work fine until I tried to remove it only to find that it had stuck like crazy to the plastic panel (you'd almost think I'd not used a mould release agent).
So I need to get some silicone remover gel and try again.    What do I need to do to get this to work?
Addendum:
I found this: https://www.wikihow.com/Make-a-Silicone-Mold
So I'll try the soap/silicone trick to 3/4 cure it before starting the process.
Thanks
« Last Edit: December 14, 2019, 01:47:43 pm by perdrix »
Offline George Edmonds
« Reply #6 on: December 14, 2019, 03:54:02 pm »
Hi David
Use a very small drill to make holes to insert bits of steel wire into damaged area to provide a good key (paper clip bits) and then repair using P38 sand and repaint.  Will not be quick to do a good job but it can be done and made invisible.
73 George G6HIG
Offline MadTux
« Reply #7 on: December 14, 2019, 08:49:02 pm »
Some epoxy with cotton fibers to thicken/strengthen it and perhaps some styrofoam as molding material
Sanding/grinding and new paintjob afterwards and it should look as new.
« Reply #8 on: January 13, 2020, 11:48:56 am »
I successfully made a mould of the diagonally opposite corner using the technique of "squidging" the silicone sealer in a jug of warm water with some washing up liquid in it to partially cure it before use.
Used a soldering iron to add some 0.8mm stainless wires to provide reinforcement.
Then sprayed the mould with mould release, taped it to the damaged corner and poured in a mix of polyester resin and white pigment (RAL9010) with hardener.
Will update when it's fully set and I've taken the mould off (fingers crossed).  I hope the pink from the catalyst goes away!
Cheers, David
« Last Edit: January 13, 2020, 11:52:11 am by perdrix »
« Reply #9 on: January 18, 2020, 02:22:26 pm »
Hmm... The pink didn't go away, and the result wasn't as good as I hoped.  I did some patching and then textured the surface with some Isopon P38 car body filler. The result isn't perfect cosmetically, but I went through all my colour charts trying to find a good colour match for the original plastic and failed.
So I've decided to leave it as is, as I don't really wish to re-spray the whole thing.
