Author Topic: J212 Amplifier help  (Read 3260 times)
Offline andybarrett1Topic starter
J212 Amplifier help
« on: July 25, 2015, 09:03:46 pm »
Hi All
I have an amplifier… A Subzero J212…Everything looks ok but I am seeing and hearing the enclosed distortion… the trace was measured at the speaker…. one trace is a sine wave (really) at 1k…. the second is a square wave at 1k.
I  am attempting to find the circuit…. early days… but has any one seen distortion similar ??
Thanks for looking
Andy
Offline pattyrice
    • DoublEElectronics
Re: J212 Amplifier help
« Reply #1 on: July 25, 2015, 10:25:23 pm »
All I can find while searching for "Subzero J212" is a speaker. Got the right part #?
Some people I know fixed one of those speakers by replacing the lowpass filter inside, it got dropped and broke a ceramic resistor inside.
Have you looked for bad electrolytic caps (bulging, fluid leaking out top) in the amp and the speaker?
« Reply #2 on: July 26, 2015, 12:55:39 pm »
Hi
Yes it is a J212A….. Circuit diagram enclosed. I had another look today… All Caps are fine and LCR says they are  in tolerance . The supply rails are fine at +/- 60v DC minimal ripple.. The bases of all power o/p transistors are all reporting the same biasing.
I have taken the crossover circuit out and still the distortion is present ….. The strange thing is if I probe the input (pin4, cn1) it an be seen there….??? (My generator op is clean and dc decoupled).
Confused…. !!!
Offline mij59
« Reply #3 on: July 26, 2015, 01:15:06 pm »
Start by checking dc voltages e.g. output of the amp, zener diode ZD1, voltage across the resistors R9, R26.
Offline dom0
« Reply #4 on: July 26, 2015, 01:19:40 pm »
Yeah, check the DC operating points first. Check if the AB bias is correct (C-E of Q7 should be about 2-2.5 V or so). Check that Q8 and Q6 don't come into conduction. Check that R19-R24 have good current sharing. Check that R9 and R26 have about one Ube accross them. If not, check Q5/12/15/9.
« Last Edit: July 26, 2015, 01:21:20 pm by dom0 »
« Reply #5 on: July 26, 2015, 07:14:41 pm »
Hi thank you…
All DC points look ok… 60vDC and 15vDC Rails….ZD1 has a healthy 15v…. It is a 15v Zener.
Transistors are all good both static and dynamic…. A couple have low resistance in the area but fine.
What is confusing is the distortion is present at the input… This can not be right ???
Thank you for help
Offline dom0
« Reply #6 on: July 26, 2015, 07:17:00 pm »
No... no that can't be right.
Unless your signal source is the culprit, or the input stage is amiss. Is the GND connected nicely and all?
« Reply #7 on: July 26, 2015, 07:25:03 pm »
Hi
Signal source is clean…. looks pretty on a scope  :-+ Ground all good :-)
Shack is trashed right now so will revisit tomorrow… I may try another sig source anyway …. maybe put a cap / transformer  in between sig and amp just to see what going on….
To make things harder second scope lead gone faulty now !!!!!!!
Andy
« Reply #8 on: July 30, 2015, 08:14:56 pm »
Amp is now sorted  :-+
A track from Q8 to the PA Bases was not good…. Not there….. Missing !!!
A production fault … So much for thermal conditioning / Soak tests !!!
So….. Got it working on bench…. Put back together tomorrow !!!!
Thank you for all suggestions……Appreciated   :-+
