Hello all!
I have a small diy CNC machine, no problems with machine outside of today’s attempt as updating psu.
My old (functioning) psu is a 24v 125w, nothing exciting, I need 5v for some extra features so I picked up a psu from jaycar, Which is a seemingly generic Mean Well rd-125b, Same form factor, same bus, mounting holes with the addition of dual voltage.
Problem I have, the psu I bought won’t power up. It just power cycles on/off. Digital multi meter doesn’t show full 24 or 5v before next cycle. Light comes on,of,on,off etc.
I thought maybe faulty psu as I’ve never had and problems prior or other psu’s of different voltages. However the other 2 (total 3) do the same.
I have Tested on the bench,
With load.
Without load..
No problem with 240v or RCD. Using the same test cable and rcd im able to power up several others (60v 48v) that I have handy.
What are the chances of 3 psu’s being faulty? Or Is there something different with these Mean Well power supplies being from the Australian market vs the eBay variety?
Any help would be greatly appreciated.
