Author Topic: Jaycar TS-1574 Digital Station Has No Temperature Readout  (Read 1860 times)
Offline cz1234Topic starter
« on: March 13, 2018, 05:32:13 am »
I have a Jaycar TS-1574  Digital soldering station
Has been working until today
the soldering soldering side of the temp readout lights up but is blank
The reworking side works fine still
Nothing except the light is showing on the soldering side of the display window. Soldering iron does not heat up
Is this an easy fix or time to buy a new soldering station
Pic is with no iron attached but it makes no difference if iron attached or not to the display window
Offline stj
Re: Jaycar TS-1574 Digital Station Has No Temperature Readout
« Reply #1 on: March 13, 2018, 02:36:23 pm »
made by zhongdi (ZD912)
http://www.china-zhongdi.com/products.asp?CataID=134&cataupper=&k=&Page=3
check the soldering on the board and maybe change small electrolytics.
afaik spare boards are available.
Offline saabman
« Reply #2 on: May 18, 2018, 04:59:56 am »
Check the two electros  at the top of the pc board E1 330uf 25v E4 100uf 25v. and also the 5v regulator labeled VOL in the top left of the pc board.
Offline Electronika
  • Country: ar
« Reply #3 on: September 17, 2018, 04:09:27 am »
Hi. will you have the station's firmware?
Offline Rasz
    • My random blog.
« Reply #4 on: September 17, 2018, 08:41:47 am »
https://allegro.pl/plytka-sterownik-z-lcd-do-stacji-zd-912-zd-915-i6285704079.html
$13
electronically iron/desoldering gun/hotair appear to be the same, but I suspect different firmware, because they label them separately
