Hello everyone,
I recently got a JB Systems B2-1500 PA Amplifier which has one channel stuck in protect mode. I am trying to repair it, but I’m out of ideas. The right channel seems to be faulty and the left one seems to be alright.
The most common cause of protection mode is a blown power transistor/mosfet in the output stage of the amp. I checked them all by using a multimeter on the diode tester mode and they seemed to be all fine.
Both the thermostats,(on each channel of the amp), measured the same resistance when I desoldered them.
After that I made sure that the amp is receiving the right amount of voltage. I could compare the voltage of the faulty side to the voltage on the other side. The voltage on the main rails was equal on both channels. So this also shouldn’t be the problem.
Capacitors that have gone bad could also be the cause, (I know it’s a crude way to measure the ripple voltage) but I measured the AC voltage on the main power rails. The AC voltage was exacltly the same on both channels. It was approximately 2.6VAC.
The only difference I could spot between the two channels was the output voltage (AC) at the speaker terminals. There was no voltage on the working channel, but on the faulty channel there was around 4.75 VAC present on the speaker terminals.
I think this is very weird. Normally if an amp goes into protect mode, the speaker relay opens, and there is absolutely NO voltage at the speaker terminals. Could the relay be broken? Is it because of that the amplifier thinks it should go into protect mode?
I hope someone has any ideas, if you do, please let me know.
Thanks in advance!
