I think I found the result of the problem - Q12, Q15 and Q19 mosfets are not driven while Q11, Q13 and Q18 mosfets are turned on with gate pin voltage almost same as source pin and getting warm 30-31C without heatsink, 0,5 and 0,8 volts at the output of inverter. R31 is tied to ground at the power supply area.
